josh9mille
josh9mille's Avatar
10.14.2010, 04:09 PM
Corey. It's not hard. There's a bunch of threads on the traxxas forum that'll guide you if you need pics. Just unsolder the wires from both titans, twist them together (the titans are wired in parrallel, use both sets of wires) and solder them to the brush assembly where the spade connector goes. You'll probably have to enlarge a hole in the motor mount with a file or dremel. Worst part is getting the stock pinion off the motor and making a flat spot on the shaft for a rc pinion. I cut through the pinion with a dremel as much as I could, then put a flatblade screwdriver in the slot, twisted it to break the pinion.
TexasSP. Yea mine is all stock too, got it used and never checked or shimmed the diffs either. It took the dewalt, cc2200 on 5s for a long time, the 1520 on 6s finally killed the rear diff, but it took quite awhile. Oh, and I have my slipper locked too, I know someone out there is cursing my luck after hearing that! The dewalts are a nice setup for bashers that don't need to go over about 30mph. Over that and you should start thinking about a 2 speed trans to keep the evx2 happy. If my 1/6 emaxx starts getting heavy I'll go with a 1520, otherwise it'll be a dewalt on either side of the cd. Rather the dewalts because I won't be tempted to check the temps while pounding it. Either way I'll waterproof my v5 mmm and run a bigger fan on it.
Also dont forget to use the diodes from the titans or you will have horrible glitching problems
Overdriven
Destroyer of Tires
Overdriven's Avatar
10.14.2010, 04:36 PM
Forgot about that. Not having to worry about glitching with 2.4 will do that to you. As far as kershaw goes, I was just voicing my opinion that the dewalt is a better option than a single kd motor. As a matter of fact, some dewalt users on the traxxas forum use his "overdrive" pinions in conjunction with a 2 speed tranny to get over 40mph out of their trucks.
Coreypetro
10.14.2010, 05:13 PM
@Overdriven- So no diodes needed with the 2.4 ghz? That's cool! I never understood why they don't put 2 speed trannys in electric from the factory. What kind do you recommend? What's the selling points of his overdrive pinions?
Kershaw designs
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Kershaw designs - 10.14.2010, 06:11 PM
Yea just like MonsterMike Dan has been playing around in this hobby for quite some time and has a pretty good idea of how these things work. He has allot of options available for spur gears and pinion gears and will gladly suggest the best idea for your preference.
I would put the diodes on the motors anyway, but thats your choice. You will have fun with using the Dewalt motor, and it will hold up well to most anything you put on it. They are a fun alternative for brushless and much cheaper. They are considered the novis choice and a great way to learn more about our hobby.
SUPERMAXX YOUR LIFE.
Overdriven
Destroyer of Tires
Overdriven's Avatar
10.14.2010, 07:21 PM
I didn't use diodes and suffered no ill effects with my 2.4 radio, but it is a good idea to do. Kershaws overdrive pinions are just really big. They are needed on some of his kits, and can be used with the dewalt too. The only 2 speed kit I know of for the erevo and emaxx is the traxxas kit. You should check out these threads, lots of info in them.
http://monster.traxxas.com/showthrea...ghlight=dewalt
http://monster.traxxas.com/showthrea...ghlight=smoked
http://monster.traxxas.com/showthrea...t+installation
Coreypetro
10.14.2010, 08:28 PM
Yeah, I checked out that 2 speed kit on the Traxxas site and it looks like you need to manually switch gears from the transmitter not like the self shifting trans on my nitro trucks. What's up with that? Who wants to buy a 3 channel transmitter for that?
Big House
Big House's Avatar
10.14.2010, 11:41 PM
Originally Posted by crazyjr View Post
another reason, there are some setups not truly made for brushless, Like the traxxas summit. Soft long throw suspension without swaybars and overpower do not mix
That is understandable, but I would think you get a low KV brushless system, that is not putting out the power but the torque, power it according.
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
Drivinfast247
10.16.2010, 10:29 AM
Auto shifting 2 speeds are used on nitro vehicles because of the lack of low rpm torque produce by a nitro motor. It helps them accelerate quickly and also reach high speeds. An electric, especially brushless motor has very linear torque, and lots of it, so a low 1st gear is not needed. Some elec. models come with a manual shifting 2 speed to make driving in different terrain easier. Say you wanted to drive up a steep hill, you could shift into 1st and power your way up. But after that, you wanted to cruise down some trails, just shift it into 2nd and goose the throttle.
But a properly geared brushless motor and some lipos will tear off the line and make your pants heavy with its speed.
Dewalt motor in Summit is great!
Traxxamus
Dewalt motor in Summit is great! - 10.30.2010, 05:57 PM
Hi guys, I have have a dewalt 12 volt xrp motor in my summit with a Castle Mamba Max esc running a 4s 6000 45c battery arrangement. I started with a 14.4 volt Dewalt motor out of a new drill I have had for about 9 years. I ran an 18 tooth pinion with the 68 tooth spur gear, I then bought a 12 volt motor and installed it with a 16 tooth pinion running the same spur. I am very happy with both setups. The 12 volt gives me a little more acceleration and a little more top end but the gear noise is much higher with the smaller pinion. I can bash around till I get tired of driving (about 30 min) and put in about 2500 mah back into the batteries. The motor temp is fine (for a Dewalt) I can just hold my hand on it for about 5 seconds. The esc hardly gets warm,(the only way I could get the fan to come on was to climb my legs at a really steep angle in second gear for about twenty minutes) and the batteries are just a couple of degrees hotter than ambient temp. I also bought an 18 volt dewalt motor and I am going to try it on 6 cell lipo as well as the 14.4 volt motor on 6 cell lipo. I noticed that even though I am on 2.4ghz, my radio range was reduced to less than 1/3 when I didn't use the noise suppression capaciters on the dewalt motors, so needless to say I installed a pair of .1uf ceramic caps. onto the motor and my range returned to what it was when I had the stock Titan motor installed. I learned another thing about these Dewalt motors, the older new styles have a rear bushing and are single wound and the latest style has a rear ball bearing and is double wound. I put a drop of locktight on the rear bearing housing to lock the bearing in place because the outer race was spinning slowly in the bore of the rear housing when I was breaking in the motor. (this was a new motor). I am having an issue with the Castle esc. In brushed mode, the esc goes right to reverse instead of breaking first if you coast for more than about 1 second. I tried different settings and it is still the same. I installed the esc in my brushless e-revo and it was fine, so it appears that it only has a problem in brushed mode. I called Castle Creations and spoke to their techs and they said it sounds like a software issue, so I am waiting for them to get back to me with a software solution for the braking issue. (Nothing like coasting a second on asphalt in second gear after winning a race and then touching the brake and watching your Brand new Summit do an endo onto its roof and slide down the road!) Well I broke in the body anyway!
