Mamba Max Pro infos
immarcescibile
immarcescibile's Avatar
Mamba Max Pro infos - 11.29.2010, 12:53 PM
I'll use a Mamba Max Pro as official ESC with my brand new 1512 - 1800Kv engine and 4s-40/50c-4000/5000Mah batteries...Should I use a Castle external BEC with 4s configuration according to you guys??
I'll have an Ace1015 steering servo or a Sanwa Erg-WX...
And should I use any external capacitor soldered to the deans (to guarantee protection in intensive usage - considering the 4mmq "little" cables)??
Any particular issues/mods to do to have a reliable Battery/engine/ESC system with my components??
Thanks in advance!
11.29.2010, 01:31 PM
What car is it going in? MMPro is best for 1/8 Buggies or vlight trucks
With some high power servo's a BEC seems to be in order with the MMPro.
No need for extra caps IMO with that setup.
immarcescibile
11.29.2010, 03:30 PM
MBX6 brushless buggy + Ace1015 steering servo or Sanwa ERG-WZ...What does - With some high power servo's a BEC seems to be in order with the MMPro - mean?? Sorry but, as I'm Italian, sometimes I don't understand perfectly :-)
So no need of external bits with the above configuration????
11.29.2010, 03:48 PM
I would use an external BEC.
immarcescibile
11.29.2010, 03:49 PM
Like Catles Creations' one??
11.29.2010, 03:59 PM
yes - they are v good
simplechamp
simplechamp's Avatar
11.29.2010, 04:07 PM
I would do this: try first using internal BEC, if you have issues try a cap on the RX, if you still have issues use the CC BEC.
immarcescibile
11.29.2010, 04:55 PM
simplechamp, tnx for repling me, please can you explain -try a cap on the RX- better? I didn't understand the mod, sorry.
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
11.29.2010, 05:13 PM
I think he means put a capacitor on the positive and negative leads of a spare channel on the receiver. Something like this:
http://scriptasylum.com/rc_speed/_pi...20lvc_1.gif~18
The capacitor will help hold the voltage going to the receiver up near 5 or 6 volts. If it goes too low, the radio system will turn off and you will lose control.
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
immarcescibile
11.29.2010, 05:25 PM
Yes, that image helps me a lot, thanks!
simplechamp
11.29.2010, 05:44 PM
Yes, I had issues with the MMP internal BEC and the cap fixed the problems for me. It helps reduce the "brown outs" caused by the voltage dropping in the internal BEC. Some servos cause the issues more than others, if they are very high-torque and power hungry.
You want a cap described as "Low ESR", rated for about 10-15V, 105C, and approx. 1000-3000 uF
immarcescibile
11.30.2010, 03:56 AM
Any link of where to buy it or see it directly please?? I'll have to try to find it here in Italy and right now I don't find the right "translation" to describe it here...just let me see it trough a e-commerce shop please..
11.30.2010, 12:16 PM
http://www.rc-monster.com/proddetail.php?prod=35vcap
One of those, rated for 12v should be fine- you can also buy them wired up already:
http://cgi.ebay.co.uk/Novak-Novak-Gl...item53e450e259
it will plug right into a spare slot on the receiver ( aux/batt slot usually ).
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
11.30.2010, 01:18 PM
Novak I beleive sells one that is already wired tonplug right into your rx
simplechamp
11.30.2010, 01:31 PM
You could go for the Novak or other pre-wired ones, but IMO they are way too expensive for something you can do yourself with a few minutes of soldering and an extra RX plug. Mike's caps are much more reasonable, but they are 35V caps and will be very large in size compared to a 10V cap of the same capacitance, they will work though (but are also currently listed out of stock).
I get mine on Ebay, do a search for "low ESR capacitor" and look for the specs I listed in my previous post.
This was just one I found first, shipping from China though, but free shipping: http://cgi.ebay.com/20-NIPPON-10V-22...item53e4e8b0c6
20 is probably way more than you need, but for the price is doesn't hurt to have them in your parts bin, you'd pay the same price for one Novak cap.
Here's another from Romania: http://cgi.ebay.com/Fujicon-Electrol...item5add72ddd2
