Thread Tools Rating: Thread Rating: 16 votes, 4.75 average. Display Modes
jhautz
jhautz's Avatar
12.02.2010, 10:50 PM
Originally Posted by GO-RIDE.com View Post
Hey Bryan,
How do you think a 810E buggy (Ten-T in buggy trim) would run with a Tekin SC4X 3400 motor & RSPro ESC on 3S. I'm looking at building a light 1/8E buggy for indoors and saving weight on the motor/esc/lipo would help a lot.
I think it will run great.
Just starting that exact project now. Only Im using a Novak HV 7.5 instead. Got it for $65 on the novak site. With Mikes conversion kit and 3s Hyperion 6500 pack. Shooting for a sub 6lb 1/8 buggy for racing indoors this winter.
Im starting a separate thread on it now.
http://www.rc-monster.com/forum/show...220#post389220
to make it...
or break it...
Silent...But Deadly
bryan
bryan's Avatar
12.02.2010, 10:52 PM
CASTLE 1512 1800KV"on sale" W/MMM or MMP.Inexpensive fast and a high quality product.Castle also has a new line of s/c motors now you may want to check out.
bryan
bryan's Avatar
12.02.2010, 10:54 PM
Cant wait to read about your build JHAUTZ
GO-RIDE.com
12.05.2010, 01:03 PM
Thanks guys. I'll follow your new post JHAUTZ.
E-8ight - Tekin RX8 2000kv/4S
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.11.2010, 02:54 PM
Finially ordered mine !
After I sell the messy stuff and the radio, Mikes kit will be next.
Me and a buddy are trying to decide weither to go 3s or 4s running a 1512 1800kv motor
The trucks are primarly for the track with a little bashing.
Objective is keep it light as possible hence wanting to use the 3s and MambaPro but the 25T pinion and low RPM's make me wonder if 4s would be better suited ?
Your opions please ????
Heres with 3s
Differential Ratio: 3.888888888888889
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 52
Pinion Tooth Count: 25T with little gearing options
Total Voltage: 11.10
Motor KV: 1800
Tire Diameter (inches): 4.5
Tire Ballooning (inches): .10
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 2.08 : 1
Total Ratio: 8.08889 : 1
Tire Circumference (inches): 14.77 inches (375.04 mm)
Rollout: 1.83:1
Total Motor Speed: 19980 RPM to low ?
Vehicle Speed: 34.54 mph (55.48 km/h)
Effective KV Value: 1800
KT constant: 0.75 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
And 4s
Other Ratio: 1
Pinion Tooth Count: 20
Total Voltage: 14.80
Motor KV: 1800
Spur/Pinion Ratio: 2.6 : 1
Total Ratio: 10.11111 : 1
Rollout: 1.46:1
Total Motor Speed: 26640 RPM
Vehicle Speed: 36.84 mph (59.18 km/h)
12.11.2010, 04:11 PM
I personally would go with 4s on an 1800kv motor. If motor rpms are too low, especially on sensorless, startup may be a bit rough. Of course, if using a sensored setup, this isn't a concern.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.11.2010, 04:22 PM
We will be running sensorless,
Thanks for solidfying my thoughts sir.
Curious about your run times whom run on 4s, what could I roughly expect with 4000mah packs ?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.11.2010, 10:03 PM
I know this is a very popular combo for buggys but what about for this application ?
3s, MMPro, 2650kv
Comments ?
Other Ratio: 1
Pinion Tooth Count: 19
Motor KV: 2650
Motor Coil Resistance: 0.0035
Spur/Pinion Ratio: 2.74 : 1
Total Ratio: 10.64327 : 1
Rollout: 1.39:1
Total Motor Speed: 29415 RPM
Vehicle Speed: 38.64 mph (62.07 km/h)
Effective KV Value: 2650
KT constant: 0.51 oz-in/A
12.11.2010, 11:40 PM
3s on the 2650 motor would be better rpm-wise IMO.
I run 4s on the Tekin 1700kv buggy motor setup and get around 25-30 minutes of runtime at a rough guess.
bryan
bryan's Avatar
12.12.2010, 01:58 AM
3s 2650/4s 1512 your gaining weight and losing weight somewere else.Jeff i friggin love mine with the 1512 on 4s.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.12.2010, 10:37 AM
Thats the run time I looking for, or dang close
I know I know, But I'm a little concerned 4s might be a bit much for the track. I'm trying to set my buddy up the with the same set up but he's not as able to control the power, he's realitively new to BL so 4s he's gonna be all over the place. He's a few weeks behind me on building his so I reckon I'm just gonna have to expeiment some, just hopeing to save myself haveing to rebuild mine 2-3times to find the perfect track combo.
Thanks for your help gentlemen
lucias
lucias's Avatar
12.16.2010, 01:29 AM
what bodies are you guys running on your ten t's? any after market ones fit ok?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.16.2010, 09:15 AM
I have yet to have my 10T in hand but was thinking Stampede bodys might be perportionate ?
When I ordered mine this week I went ahead and picked up a clear body also, as great as the stock bodies look theres only 2 colors, kinda lame selection.
H e l p !!
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
H e l p !! - 12.17.2010, 02:50 PM
Someone help me please !
What are the ID measurements of the RCM Ten-T battery tray ???
THANK YOU!
bryan
bryan's Avatar
12.17.2010, 03:16 PM
THANK YOU!
50-160mm
