12.24.2010, 06:50 PM
Wow, what a beast, and it fits perfectly into my baja5b conversion kit that I just have finished.
Awsome. Have to buy one of this motors and test it.
Dejan
12.24.2010, 06:51 PM
Originally Posted by Cody.McP
Hi, yeah I picked the 4200mah Hyperions because they are going to be used in my other cars as well and I like the smaller dimensions and lighter weight of them. If they were to be used only in the baja I would have gotten at least 5000mah+. I am also going to be using two 4s pack in series for 8s 4200mah total so you have that right :)
And I am going to be using Mike's conversion kit.
There are just 2 deans that I am aware of. The micro Deans and the regular Deans, I'll just be using regular and I think they will hold up just fine. If not, I will switch up to deans connectors.
ow I see, nonetheless its great man!
let us know how the baja power works out with the those batteries and with the Castle kit :)
ps: did you make a mistake in your last sentence? :)
You've been hit by, you've been struck by a smooth criminal
12.24.2010, 07:05 PM
Haha yeah, I meant switch up to bullet connectors. Oops! And I'll let you know how it all runs soon! Most likely on Monday when I get my batteries, but it could be sooner on 6s. I'll keep you guys updated.
12.24.2010, 07:10 PM
cool dude! I'm sure we all will be waiting for your findings! ;)
and could you also post some pics of the conversion kit with the combo in your baja + with the batteries?
I would like to get a visual how tight the batteries sit and how much room left there would be.
+ a vid would be cool of course as well :p
12.24.2010, 07:24 PM
Yup of course! Once I have some free time this weekend to tinker on it I will start a build thread and psot up a bunch of pics  and then I'll try to work on a video but it depends on how the weather goes.
12.24.2010, 07:36 PM
even better! ;)
12.24.2010, 09:53 PM
FYI I posted up the conversion manual for the baja in the manual thread last weekend. :)
12.25.2010, 05:15 AM
Originally Posted by Pdelcast
HV ICE uses Infineon BSC031N06 (3.1 milliohm, 60V)
Mamba XL uses Infineon BSC019N04 (1.9 milliohm, 40V).
Hi Patrick, what are the Specs for the FETs in the current Hydra line? the specs above point to a possible future Hydra Ice 200A HV ESC only 50% bigger and more expensive than the possible future Hydra Ice 200A LV ESC,
whereas the current Hydra 240HV Looks like its twice the size and close to twice the price of the current Hydra 240LV, have HV FET improvements narrowed the size weight and cost difference between HV and LV ESCs?
Paul.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
12.25.2010, 04:35 PM
hmm, I read on a board that Deans wouldnt be sufficient enough, they can only handle max 60amps....so I assume deans connectors are not done with this system?
12.25.2010, 04:49 PM
deans are rated at 60 amps for safe use. I swear by deans and will use them on my e5b. You will never sustain a 60 amp draw. Deans should be fine.
I have never ever ever seen a melted deans. If you melt a deans you are doing something seriously wrong.
12.25.2010, 05:31 PM
I looked in the "every manual you ever need" sticky in the general section and couldn't find it.
Could you provide a link for the pc challenged?
12.25.2010, 05:47 PM
http://www.rc-monster.com/forum/showthread.php?t=19913
12.26.2010, 12:26 PM
Hi all, what about the BEC of Mamba XL ?
I've read its capable of 5 ampere, so I wonder whether I've to use the ESC without external BEC or not (initially I would use the ESC with 6s only on a 1717)
Bye, Andrea.
12.26.2010, 01:38 PM
lol the 5 amps is for the bec that is already build into the esc...
12.26.2010, 03:59 PM
Yes, I know and this is the same for the internal BEC of Mamba Monster, however, with the Monster, I do prefer to use en external BEC when I go with 6s.
My question was if I should do the same with the XL.
Bye, Andrea
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
