MMP able to handle this Motor?
JoFreak
JoFreak's Avatar
MMP able to handle this Motor? - 01.02.2011, 01:59 PM
Hi,
I just ordered a 6-Pole 5000kV motor (1000 Watts) for my Slash 4x4.
Now I started wondering if the MMP will be able to handle this motor on 2S LiPo?
Especially the 6-Pole part of it.
01.02.2011, 04:59 PM
Link to the motor specs?
JoFreak
JoFreak's Avatar
01.02.2011, 05:10 PM
Hi Linc,
it's not a CC Motor, so I won't post it up in the Castle section.
Sent you a PM instead.
samintrepid
samintrepid's Avatar
01.03.2011, 12:35 AM
I think not but i am not sure at 100%, The next castle sc combo are 4800kv and need mamba monster because he drain too much amp for the MMP.
nuz69
nuz69's Avatar
01.03.2011, 01:19 PM
The amps doesn't depend of the motor but of the setup (ratio, weight of the vehicle, etc...). I would wonder about the commutation speed required to run a 6 poles 5000Kv motor. The mmp can run a 4 pôles 5700Kv (new Castle 4 poles motors for 1/10scale), so I don't know if it can run a 6 poles 5000Kv motor. Just wait another reply of Castle guys.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
outlaw
Castle addicted
outlaw's Avatar
01.03.2011, 03:06 PM
I guess, i know what motor he ordered
20mm long 38mm diameter 6 Turns
On 2S the MMP will handle it just fine
This motor likes high timings ! around 15 to 20 degrees
Make sure you have "biffy" batteries
kind regards
Mirko
Brushless motors have to be green ....
JoFreak
JoFreak's Avatar
01.03.2011, 03:09 PM
Well big surprise!
It's because of you I got the idea to get that motor in the first place
But I think you mean 40mm long
outlaw
Castle addicted
outlaw's Avatar
01.03.2011, 03:39 PM
Hmmm 40mm long ????
kind regards
Mirko
drkdgglr
01.04.2011, 04:44 AM
Last weekend I had my first run with a MMPro in a Slash 4x4 with a 6 pole brushless motor (1530kv @5s). I have it setup for the same speed as a stock Slash 4x4 on 2s. After 30minutes of bashing the motor reached 44c and the MMPro was 15c.
The setup needs some fine tuning in timing. The manufacturer recommendend 5 degrees timing, but on forums I've read that 20-25degrees timing is best. So that will be my next attempt.
outlaw
Castle addicted
outlaw's Avatar
01.04.2011, 07:46 AM
Hmmm looks like you got the same motor, i have, just with different "T's"
Sounds like a 10T one
Slash on 5S ? Thats a lot power. how much mA do your batteries have ?
I have 3S 6500mA and get almost 25min runtime Indoor so around 73Wh
A 4000mAh on 5S would be around the same (74Wh)
kind regards
Mirko
drkdgglr
01.04.2011, 08:04 AM
yep, mine is a 10. I'm running a 5s3000mah 40c zippy.
So, if you're running the same motor, do you also get a minor glitch a very low speeds? When I 'crawl' along it suddenly boosts forward a bit. This only happens with very little throttle.
outlaw
Castle addicted
outlaw's Avatar
01.04.2011, 08:09 AM
OK Thanks for that
No cogging
I can crawl' are real low speed but i have seen the "sudden boost" some time as well
But on the CC2200 Motor, i have seen the same.
I use 10 degrees timing currently and no Punch Control
Low Start Power
But over all MMP and the Motor are a great combination.
I'm more than happy
kind regards
Mirko
drkdgglr
01.04.2011, 08:12 AM
Have you tired different timing settings?
I believe my motor temps were too high, considering I'm only geared for 30mph. Maybe I'm undergeared...
outlaw
Castle addicted
outlaw's Avatar
01.04.2011, 08:17 AM
100% undergeared ! Those Motors don't care much about gearing
We had a test with the /7 on MMP in a SC8 compared to the CC2200 Motor (same KV)
The /7 does take 15-19 pinon and does not care ;-)
On higher timing, you will see less temps !
BTW the magnets can handle up to 180 degrees ! on all of them
10 degrees was just a test, i will go back to 18-20. But without Sensor, the MMP can't do more than 20.
I wish a 2240/10 would come around my house... compare 3S to 6S
Castle, maybe this would be a welcome change for the firmware, to allow maybe 25 degrees of timing, without sensor
kind regards
Mirko
Pdelcast
Pdelcast's Avatar
01.04.2011, 02:19 PM
I'd be suspect of any motor that has both 6 poles, and needs THAT MANY TURNS to get a decent Kv.
Patrick del Castillo
President, Principle Engineer
