outrunner size/kv for 1/16 summit ?
speedy
outrunner size/kv for 1/16 summit ? - 03.01.2011, 12:30 PM
hi !
if i whant to replace the centergearbox and motor in a 1/16 summit truck with a outrunner motor ! how big does it need to be and what kv rating ?
03.01.2011, 01:00 PM
You can use the parameter solver to get motor kv value needed:
Enter your:
- Enter the tire size
- Enter the differential
- Enter the battery voltage
- Enter your desired speed (if you want to keep the same speed you have now, calculate your current speed using the Top Speed Estimator Calc).
- For the transmission, enter 1 (outrunner is replacing this).
- For the spur, enter 1 (outrunner is replacing this).
- For the pinion, enter 1 (outrunner is replacing this).
- Leave the motor kv value blank
- Click the "calculate unknown" button.
The motor kv shown will be the motor you need.
03.01.2011, 02:04 PM
After you find the kv via BG's method (listed above) I think a 28 size outrunner would do. The longer outrunners will provide more torque. You may be able to get away with a long 22 size outrunner. Not a ton of space to work with on the mini revo platform...
