trev3813
Dsm needed
trev3813's Avatar
03.07.2011, 12:45 AM
Not to jack a thread, but would a 3800 be good in a 2wd rustler? im buying a sw combo here soon and looking for opinions.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.07.2011, 12:58 AM
The only problem will be traction-
2s = Fun
3s = Insane
4s* = 2012 is your fault.
*I don't think the SW can handle 4s, but if it could...
03.07.2011, 01:28 AM
I run the combo on 3s in my 2wd pede. I would recommend it. For the price nothing can come close.
trev3813
Dsm needed
trev3813's Avatar
03.07.2011, 02:05 AM
I'll be running 2s. but back on topic, thanks for the reassurance :D
asheck
03.07.2011, 09:07 AM
Pity the sidewinder sc won't do 4s
Just out of curiosity, have you tried? I was planning on adding a bec and extra cap , just to see what kind of difference it makes with it's capabilities. But was thinking when I did, I would try 4s, just to see. Honestly my end plan is a different esc, though.
03.07.2011, 10:19 AM
I have a feeling that the castle firmware will not allow the increased voltage. Read thru the release notes for the MM updates and you will see that after v1.28 they incorporated overvoltage protection. I have a thread about it. I have a feeling they have done this across the board.
asheck
03.11.2011, 10:04 PM
Did a run today with 10/54 gearing, ran around 49mph
Amps dropped to 106. Temps were 145 esc, 125 motor
Really make me wonder about the earlier amp readings with the higher gearings. To only see a 1 amp difference between 11 and 13, then lose 10 by dropping to a 10.
Also did a 2s run, it was kinda slow at 33mph, and I could constantly hold wot. But amps went back up to 112
