Thread Tools Rating: Thread Rating: 57 votes, 4.93 average. Display Modes
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
03.29.2011, 08:47 AM
The last 8th scale center diff is sold.
No brain, no headaches.
molak
03.31.2011, 04:52 AM
Originally Posted by mistercrash View Post
Update on the LST diff modification. They are awsome, I disassembled the truck for some end of season maintenance and the diffs have no sign of leakage and run smooth as silk so I just cleaned the outside and put them back in the bulkheads. That's a whole spring/summer of racing and bashing on 4S with a few times having fun on 6S so they are very durable. An original idea from Lincpimp and I thank you for it.
I can't remember if I mentioned how I install them in the bulkheads now, I shave down some material on the aluminum cases of the diffs so that leaves the bulkheads intact except for a small portion that has to be Dremeled to accommodate for the front of the diffs where the two screws are. Here's a few pics, I hope they are self explanatory. This way of doing it coupled with the diff blocks really holds up to some serious abuse.
Based on your mods.
I took 1 step futher and did a machined version of the LST-revo diff mod... Removing the exact amount of material to fit and un modified Bulkhead (but the bolt part)
Here´s and album of it.
I hope you like it!
mistercrash
Guelph, Canada, eh!
03.31.2011, 10:53 AM
That is one tight fit. Nice work on that molak.
Deahttub
03.31.2011, 04:11 PM
Molak,
Amazing work! My xxl diffs look nothing like those! I have a cpl extra cases...how much would you charge to machine them like you did??
03.31.2011, 04:14 PM
Very nice Molak, This is what I originally wanted to do. Bit I lack the machine tools, and cutting the plastic bulk is much easier for me.
I am sure those cases would sell like hotcakes...
molak
03.31.2011, 05:57 PM
Since Im from Argentina shipping costs and import duties (50%!!) will make those cases expensive!
I'll check how much that case cost in the nearest losi dealer to get an aproximate. But any machinist can do those. Maybe Mike could make them ..
mistercrash
Guelph, Canada, eh!
04.01.2011, 09:04 AM
Mike is supposed to be making his Hybrid diffs. Many peeps waiting for them.
molak
04.01.2011, 12:01 PM
I'm one of those ...
btw: LST cases are made from a quite soft material and are injected, which makes them porous...
mistercrash
Guelph, Canada, eh!
04.02.2011, 11:39 AM
Yes those cases are not the best, but they are the only option I know of right now to have an 8th scale drive line in the E-Revo.
Hey there...
bullseye0169
Hey there... - 04.07.2011, 04:35 PM
Based on your mods.
I hope you like it!
Dude where did you get those brass inserts that you have used in the bulkhead???? I have a new bulkhead and found that some of the holes are striped right off the bat. I would really like to find those and put them in my truck... Thank you for your time...
molak
04.08.2011, 12:53 AM
You should ask to Mistercrash.
But i think he used something like this
http://rtlfasteners.com/RC/655.html
mistercrash
Guelph, Canada, eh!
04.08.2011, 09:13 AM
Those could work Molak. The ones I used I found at Tower Hobbies. They are distributed by Dubro. They don't come with metric threads so I got some 4/40 brass inserts which I tapped with M3 threads and some 8/32 inserts which I tapped with M4 threads. A trick I use to screw the inserts in the plastic is to heat them a bit with the flame of a lighter or even a heat gun. I heat them up just enough so they are easier to screw in the plastic. I let it cool and then I can extract the screw that was used to insert the insert.
feistyacorn
feistyacorn's Avatar
04.08.2011, 11:26 AM
Otherwise Tony's Screws has 4mm ones. Next time I order from him I was going to pickup a set. He has nice deals on very high quality hardware.
http://www.tonysscrews.com/product.s...&categoryId=12
mistercrash
Guelph, Canada, eh!
04.08.2011, 11:53 AM
I tried the Tony Screws style inserts and after a couple started twisting in the plastic preventing me from removing the part, I went back to the screw style inserts.
feistyacorn
04.08.2011, 12:13 PM
Thanks for the heads up MC! I know what would solve our bulkhead issues.... the FLM combo bulk! Hopefully soon...
