Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
D8t
Luda
D8t - 07.13.2010, 04:48 AM
Hi,
will slipperential fit into HB D8T?
Use someone this configuration?
Thanks
H&P CUZTOM RC
07.13.2010, 07:01 PM
well if ya ask me i think tha slipperential is da bomb!!!! im puttin one in my nitro savage, and no its not brushless!!! im talkin a full mod lrp zr.30 folkz!!!!
bryan
bryan's Avatar
07.13.2010, 07:43 PM
Thanks for supporting RCM
georgec
georgec's Avatar
07.14.2010, 06:42 AM
Originally Posted by Luda View Post
Hi,
Thanks
Yes it will fit the D8T.
Here's what it looks like installed with a Kyosho motor mount.
And here with a RCM motor mount.
georgec
georgec's Avatar
07.14.2010, 06:48 AM
Umm...Why? Is this not like running two clutches?
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
07.14.2010, 05:04 PM
Running it in a nitro is not unheard of, actually - there will be two clutches, but the Slipperential diff can be adjusted in the vehicle quickly trackside, while a nitro clutch must be dis-assembled to make adjustments.
Gallagher
07.05.2011, 02:12 AM
Does this work in Durango DNX408? Any mod. necessary?
I am planning to convert DNX408 into brushless version with my lhs. conversion kit.
By the way, still I am looking forward to RCM conversion kit. I hope it is coming soon.
RC-Monster Mike
Site Owner
07.05.2011, 10:07 AM
Not sure on the Durango fitment - never had one in my posession to make the call. most likely, the Slipperential will fit, though.
Gallagher
07.22.2011, 09:50 PM
Slipperiential requires 1mm to 1.1mm shim to fit in DNX408.
Bearings should be replaced with 8*14 mm flanged bearings which come with DNX408.
After that you are good to go.
O'Donnell
DR STATIC
DR STATIC's Avatar
O'Donnell - 11.17.2012, 04:39 AM
I've seen the question asked, but no response. Would this work on the O'Donnell Z01T? Please let me know. Thank you.
RC-Monster Mike
Site Owner
11.17.2012, 11:16 AM
Yes, it will fit the O'Donnell buggy and truggy - it will require some shimming, as it is physically shorter between the bearings.
georgec
georgec's Avatar
11.18.2012, 07:59 AM
Hi,
Thanks
Yea it works great in the D8T and D8. You will have to shim the bearings quite a bit but that doesn't change how well it works.
