6s setup for 1/16 summit?
speedy
6s setup for 1/16 summit? - 08.13.2011, 05:35 PM
What do you guy's think of this setupnfor a 1/16 summit?
Mm-pro + 6s + 1500ish kv motor geared for 45mph would that be an good
setup?how long runtimes could i get?
Fore lipo,s i was thinking of using a pair of 1000mah 3s 30-45c packs to save some weight compared to the 1500mah 3s pack that i run now wth thecstoch setup !
scarletboa
scarletboa's Avatar
08.13.2011, 09:23 PM
i like the idea a lot. the only problem is finding a good, 1300-1800kv motor (preferably 4 pole)
good luck with the build and pics, as always, are expected
speedy
08.14.2011, 12:53 PM
How about a mega 16/25/motor they have 6poles ?
If i whant an outrunner that has equal or sligtlyĺ more tourque than a inrunner in stock motor size ! How big does the outrunner have to be?
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
08.14.2011, 02:52 PM
Good luck having the diffs hold up! The diffs are worse than the full size revos, I was blowing apart diffs on 2s after a few runs and on 3s I was lucky to have a diff last for more than an hour
Semi Pro
Semi Pro's Avatar
08.14.2011, 10:53 PM
my diffs held up fine to the cm36 7700 on 3cell lipo and mikey84's diffs are holding up fine to the cm36 9000kv on 3cell so i think it really depends on the way you set up your diffs and how you drive it.
i
