Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
custom cut spool for gtp2e
scrivtwin2
custom cut spool for gtp2e - 03.15.2012, 12:07 PM
how do i go about ordering a spool from the gtp cut down to fit the traxxas 34t spur? i tried pming but that didnt seem to work right(doesnt show i sent any) so i figured i create a topic
snellemin
2 KiloWatt RACER
snellemin's Avatar
03.17.2012, 01:37 AM
Traxxas only has 36T spurs. Integy is the one with the 34t spur. So you want to run a 1:1 ratio of 34 spur and 34T pinion?
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
scrivtwin2
03.17.2012, 06:22 AM
yeah thats rightlol
im probably still gonna run a 26t pinion with a 36 or maybe even a 40tspur for now but i would like the option of gearing up later on. really i would like to just hit 100 with it before this other guy here in town doeslol
03.17.2012, 07:28 AM
Originally Posted by scrivtwin2 View Post
yeah thats rightlol
get a higher kv motor
scrivtwin2
03.17.2012, 10:09 AM
why would i wanna do that?lol im sure that would be the cheaper routelol. i would rather have a lower kv bigger motor and gear it higher. i pretty much have everything i need to hit 100mph now exept the ability to gear it higher because i really cant fit a bigger gear on it. i seen this on a few cars on youtube and i rather have this done then buy the 46t spur and the spool that he sells on here because it will have way more options. (i could use mod 1 or .8 pitch traxxas gears)
scrivtwin2
03.19.2012, 11:26 AM
this is all taking care of. thanks Mike your awesome!!
snellemin
2 KiloWatt RACER
snellemin's Avatar
03.19.2012, 11:44 AM
Is Mike making you one? Would be great if he did, as I could use one as well to run plastic spurs to run at nite.
scrivtwin2
03.19.2012, 11:49 AM
yes he said he would. i just have to order the one thats on here and put in the notes that i want the traxxas edition. of course i screwed that up because i didnt see a notes section and ordered it regular by mistakelol hopefully he or one of the admins sees this
(i tried pming him again but it just doesnt show that it went through. not sure whats up)
scrivtwin2
03.19.2012, 11:54 AM
i have a question for you to. what eagle tree system do you use? i see there are multiple versions and add ons. not sure what to get?
bruce750i
bruce750i's Avatar
03.19.2012, 12:35 PM
Make another Traxxas gtp spool Mike. I just ordered one too.
snellemin
2 KiloWatt RACER
snellemin's Avatar
03.19.2012, 12:36 PM
Cool, I'll have to order me one as well.
I'm using the eLogger V4 with with Wire Leads, 70 Volts, 150 Amps version. I also have the GPS module, one temp sensor that I barely use, brushless motor sensor,Servo Current Monitor that I have yet to use, and the Optical RPM Sensor For eLogger that I also never used.
I was going to use the optical sensor on the slipper clutch and then compare that to the motor rpm. Would make it easier to find the perfect current limiter setting.
snellemin
2 KiloWatt RACER
snellemin's Avatar
03.19.2012, 12:43 PM
Yea, how and where do you select to order just the traxxas spool?
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.19.2012, 01:28 PM
You can just order an 8mm spool and select whichever spur you want but leave a note with the order when you checkout regarding the Traxxas spur gear edition. Dan and Keith - got your orders. Thanks. :)
snellemin
2 KiloWatt RACER
snellemin's Avatar
03.19.2012, 04:17 PM
Hey Mike,
I didn't get to enter my request for the Traxxas spool during checkout. I just submitted the an order for the Spool and front motor cover.
RC-Monster Mike
Site Owner
03.19.2012, 04:23 PM
Got it. Thanks. I will get these Revo style adapters done in the next couple days. :)
