rotary rocket
No Pistons
rotary rocket's Avatar
02.12.2013, 11:07 PM
rotary rocket
No Pistons
02.12.2013, 11:08 PM
One more...
rotary rocket
No Pistons
02.24.2013, 11:19 PM
The truck arrived last week. It looks impressive.
rotary rocket
No Pistons
02.24.2013, 11:21 PM
Installed the battery trays. I decided to keep the weight balanced and as close to the center line of the truck as possible.
rotary rocket
No Pistons
02.24.2013, 11:23 PM
Motor went is with no issues. The mount is nice and beefy. Conversion came with a 12 tooth pinion and locked center diff. A regular diff is also in the works.
Check out the "back bone" brace. No flex what so ever.
rotary rocket
No Pistons
02.24.2013, 11:27 PM
Then came the ESC and the BEC. I also added the extra caps for good measure.
The kit came supplied with a sealed receiver box as well.
rotary rocket
No Pistons
02.24.2013, 11:28 PM
The kit also includes a new servo tray. Very well made and well thought out.
rotary rocket
No Pistons
02.24.2013, 11:29 PM
A side shot of the center diff spool, and housing.
rotary rocket
No Pistons
02.24.2013, 11:31 PM
Wiring buttoned up and batteries in place.
rotary rocket
No Pistons
02.24.2013, 11:33 PM
Plenty of room to work in with the customized cage installed.
rotary rocket
No Pistons
02.24.2013, 11:37 PM
Ran three sets of packs through this weekend. The kit, motor/ESC performed very well. Bashing in a very large lot. Top speed is very similar to Losi 5ive trucks. Amazing low end torque. Jumps very well and controllable.
I need better tire for the loose dirt conditions.
02.25.2013, 01:20 AM
Just awesome man, I was hoping to see more of this truck.
That steering setup looks like what the Losi 5ive needs.
I think a spool is the way to go, even with the thickest oil brushless motors just heat up diffs, and heat is bad!
Is that an FM radio? Hobbyking sells 2.4 for $20
Get some video!
killajb
killajb's Avatar
02.25.2013, 10:36 AM
I recall having a discussion about the performance value of a center diff as opposed to the drawback in heat when used in a 1/5 scale electric vehicle.
rotary rocket
No Pistons
02.25.2013, 11:58 AM
Thanks -paralized-.
I'm an old school, old fart. :) I have a JR radio, but it is FM...just not 2.4
I have about 30-40 cars and trucks on this radio system, so it would be really expensive to switch.
I guess I'll tell Monster Mike to skip the center diff then. I will not be racing, so I guess I'm set.
nho1
04.11.2013, 02:37 PM
Any news if/when the conversion kit will be available?
