Hyper 7 Erevo Center Diff
Looking for a new system.... -
08.09.2006, 04:44 PM
Well after this past weekend , and deciding to go to a gmaxx chassis w a single speed setup....I was going thru my truck and was going to reconfigure my 1920/8...to lower the rpm...and I noticed it was seized....but not until i tried to use my controller to check it...and i heard a pop....and the motor did start to move...but not to fast..........so I thought about about hte following controllers ect.
9920
or
quark 125
and not sure on the motor.....can somebody help with suggestions....
thanks
08.09.2006, 05:05 PM
quark 125b for sure and maybe a 1950.....
....or go all out and stuff a 22 series motor in there....:005: :005: :005:
08.09.2006, 05:07 PM
ok...sounds good....anybody else have an input?
08.09.2006, 05:13 PM
just an idea... but instead of the g-maxx single speed, what about mikes "slipperential" that he is hopefully going to produce....
08.09.2006, 05:20 PM
it depends on cost...cause I allready have to get a new chassis and now a motor & controller to....not to mention batts....so that might be down the road...but once again it depends on the final cost...
08.09.2006, 06:04 PM
The 125 is a nice controller. I like the lehner motors for they don't over heat like others.
If you like the 1920 may try you a 1930 and see. I had one of them and it was nice.
Peace!
Country
Help support the
Rc-Monster
Buy here
08.09.2006, 09:38 PM
I would go with the 1940 at least with a Quark 125.
08.09.2006, 09:45 PM
ok...this is what I'm going to be building or allready have.....
UE rcer x suspension F/R
UE 8 spyder diffs
strobe slipper
and I plan on putting it on the following
gmaxx aluminum chassis
quark controller
so which motor & what turn....
squee you say 1940 but which turn?
08.09.2006, 09:49 PM
I would personally go for a 1950 but a 1940 on a light truck. If your truck is gonna be ~13lb. like it is now, I would get the 1950. Also, turn depends on the battery setup. If you have to buy new ones, get LiPo. I wouldn't run less than 5S.
08.09.2006, 09:53 PM
I plan on making it as light as possible and will eventually go to lipo.......so with the suspension and the gmaxx chassis ( aluminum and a single speed, it should be really light.... so which would be better 1930, 1940. or 1950....and which turn would you guys suggest
08.09.2006, 11:15 PM
Well I got a hold of mike, and he's gonna test my micro 2095 for me...hopefully it works fine...... I should know by next week hopefully......then I can make my decision then
08.10.2006, 03:35 AM
Please check this thread sjcrss..
08.10.2006, 07:57 AM
I think the 1950 7t would do nicely. If you going light weight the 1940 is lighter plus you have some 4mm pinions. I think a 1940 7t would be nice on like 4s lipo. IF you go 1930 I try a 8t.
Peace!
Country
Help support the
Rc-Monster
Buy here
08.10.2006, 08:02 AM
thanks serum, that was helpfull...
08.10.2006, 08:03 AM
Saves money and gains performance.. Only takes a bit of patience though.. :p
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
