#4
recomend lipos please -
10.23.2006, 09:27 PM
im runnin a mamba max 5700 and mamba speedy and was wondering what would be a good lipo set up. was thinkin maxamps.
10.23.2006, 10:08 PM
2s or 3s? What Mike's offerings from Maxamps are good choices. What you get should be dependent on your budget.
Custom
10.24.2006, 06:57 AM
...and what will fit in your chassis.
#4
10.24.2006, 01:27 PM
ya im thinkin 2s but rightr now i run the stock stampede but im goin to upgrade to fastlane chassis
10.24.2006, 02:30 PM
I would definately recommend maxamps lipos. they are very good IMO
#4
10.24.2006, 07:37 PM
will the 3s lipo fit the stock pede chassis?
10.24.2006, 08:30 PM
The only problem would be height. If you use some custom straps to hold the battery in and remove the rear ESC plate, then it will fit.
#4
10.24.2006, 08:42 PM
i actually think a 2s will be plenty of power. does it matter the mah i choose other then longer runtimes and more power.
10.24.2006, 09:27 PM
Max Amps 2 or 3s lipo, 12000mah!
10.24.2006, 11:00 PM
You'll need a certain minimum capacity depending on the C rate in order to get a rating of about 60amps continuous. For example, Maxamps 2s 4000mah 15C is rated at 60amps continuous, and would work. You can go higher in capacity from there.
#4
10.25.2006, 07:18 PM
alright thanx
Linear Mode
