coolhandcountry
coolhandcountry's Avatar
11.03.2006, 08:27 PM
Originally Posted by squeeforever
Wow...It got worse after I said something...Yikes...I would think he would have started typing in English...Good thing I speak Ncabzinesse...
I hope you don't say much more. I won't be able to read it. :002:
Peace!
Country
Help support the
Rc-Monster
Buy here
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
11.03.2006, 09:40 PM
well, i HAVE TOO! what am i going to do, NOT run in teh quallifiers or pray my 3800 lasts for 30 minutes of racing?? could i jsut disconnect the LVC from teh esc and rx?
  Send a message via AIM to nbcaznmaster
coolhandcountry
11.03.2006, 09:48 PM
I think you could do that disconnect thing. Never tried but sounds like a plan.
Peace!
Country
Help support the
Rc-Monster
Buy here
11.03.2006, 10:24 PM
Well, you could do the disconnect thing, or install a bypass switch. To my knowledge, all a LVC does is interrupt the throttle signal wire and sends a neutral signal to the ESC instead. You could wire a switch on this one wire and bypass the whole LVC.
nbcaznmaster
11.03.2006, 10:29 PM
ahh, i arleady got a switch for ubec, i'll just unplug!
nbcaznmaster
11.03.2006, 10:53 PM
3.8 amps is maxx charge on them. You should have two plugs. One real small and one for the esc to hook to. The small one is for balance. The other is for charging and running. The break in is not important. I didn't any way.
which selection is that? they only have MAH that goes from 200mah to 2500mah. Which one should i do? i dont want to ruin my packs.
squeeforever
squeeforever's Avatar
11.04.2006, 12:05 AM
Haha...I'll try not to....
nbcaznmaster
11.04.2006, 04:21 PM
SOME1 helP! my balancer has 3 pins, but they are in a 5-pin connecter. The pin on my limn has 3 pins. The prob is that the 3 pins on teh 5pin connecter is spred out, red and one black pin on teh left and one lonly black wire on the right! does it matter if i move the lonely pin next to the other pins so i cant fit it on the balencer. Also, it seems like the small rx style wire is hwere you charge? is this right PLEASE HELP ME FAST! I GOT sSOO MUCH STUFF TO DO for race and i dotn want ipos to not work
squeeforever
11.04.2006, 04:29 PM
Get a picture of exactly what your talking about. I will try and find out what I can on the Apache 2500 for ya. What balancer are you using?
squeeforever
11.04.2006, 04:36 PM
Ok, on the Apache, there is a lead for the power supply, its the ones with aligator clips and there is a battery lead with some sort of plug on it. Put your Deans, Powerpole, etc. on there and charge through that using a Y harness. Be sure to set the jumpers to 2500mah and 4S. Also, the balancer(s) hook to the taps of the batteries. I'm not sure what your talking about with the wires, but chances are you either need to buy an adapter (should have come with them) or you need to make an adapter. Its not really hard, but I need to know what balancer(s) your using...
nbcaznmaster
11.04.2006, 05:32 PM
http://cgi.ebay.com/ws/eBayISAPI.dll...8229&rd=1&rd=1
LOK AT THE PIC! it looks like tis charging that way, is that the way it should be?
squeeforever
11.04.2006, 06:06 PM
OK I'LL LOK AT THE PIC! lol...Anyway, how many did you order? 1 or 2? If one, you need to make an adapter to balance them both at the same time or just charge both to about 90% capacity and then do them individually to 100% with the balancer (if you need 100% capacity). If two, then just charge the packs through the Deans with the charge and hook the taps of the batteries up to the balancers and don't worry about the input. That balancer is made to charge/balance inline. Or, since you will only be charge at 2.5 amps, simply charge both packs at the same time using a Y adapter on the charger going into the two balancers (if you got two like you implied) and then the taps of the batteries going into each charger so they are being charged at the same time but being balanced by 2 difference balancers. Understand? Basically just tell me whether you have 1 or 2 balancers...
nbcaznmaster
11.04.2006, 06:55 PM
i have one ballencer, though do i CHARGE teh way they do in teh pic? with teh charge wire from apache, connecitn to balencer?
nbcaznmaster
11.04.2006, 07:00 PM
IS THAT the way i should charge? Also, the pins never lined up so i moved it so it does, but now it says "ERROR CHARGE" on the apache
ID:	1937   Click image for larger version
nbcaznmaster
11.04.2006, 07:10 PM
or is it supposte to be setup up like this, or this
ID:	1939   Click image for larger version
ID:	1940   Click image for larger version
