orange00
01.07.2007, 12:36 PM
Finished assembly. Hope have time to test and setup next week.
GorillaMaxx360
GorillaMaxx360's Avatar
01.07.2007, 07:34 PM
Nice
Sylvester
Sylvester's Avatar
01.07.2007, 09:26 PM
Looks great! Now put some lipo in there, a real Brushless setup and it will be a great machine! But im sure it will be pretty good on what your running now, too!
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
Mike.L
Mike.L's Avatar
01.07.2007, 09:27 PM
looks beautifull! Really complimenting you budd and Welcome to the fourms!
  Send a message via MSN to Mike.L
fiero_silva
01.07.2007, 11:16 PM
Very nice! Now, is it faster than the Nitro version? :)
orange00
01.08.2007, 01:03 AM
Re:Sylvester
Yes, the setup fit Stick pack Li-Po. After the test with everything ok. Will get them in mass.
Re:Mike L.
Thanks
Re fiero_silva
Don't know yet it will faster than Nitro version or not. I do this project just want to leave those Nitro maintain problem away as I'm not a frequent player. Till that moment I'm still a EP die hard fans. Just a bit worry the run time can't compare with Nitro version. And charging Li-po (especially hi cap.) will require quite sometime.
Mike.L
Mike.L's Avatar
01.08.2007, 09:17 AM
if you have a good charger anyliop battery would take the same time because your charging at 1C....
orange00
01.08.2007, 10:21 AM
Re: Mike.L
at the moment I use Orion Advantage charger.
And peak racing 3200mAH (HKD5XX, approx. USD70)
Any other suggestion? Better the size can fit normal 7.2V stick pack.
Erkan
02.07.2007, 05:38 PM
Hi guy´s
My E Hellfire iss know nearly ready also and I want to show You soon some Pictures of My Work !
I use only original Part´s and a Outrunner Motor ! the Batteries I use are 8 S Li Fe,rebuild from Elektric Tool Batterie Pack and fit as Saddel Pack - they are fastchargeable but have only 2300 Mah !
I dont know how my system works but i want to try it the next Day´s !
The Weight iss know 4,5 KG !
i Also Use the org. Brake System becaus I don´t want to kill my Flight Controler ( Hacker Master 90 Acro COmp ). The center of gravity is realy low !
Oki, Greet´s Stefan
ID:	2381   Click image for larger version
ID:	2382   Click image for larger version
Sylvester
Sylvester's Avatar
02.07.2007, 05:42 PM
Nice Erkan! Hows that outrunner working for you? That is a BIG esc!
Losi 8ight e
Serum
Serum's Avatar
02.07.2007, 05:48 PM
Nice!
Erkan
02.07.2007, 05:49 PM
Hi
i don´t know how this Motor will work in the Hellfire ! it has only 700upm per Volt but there is an other avaible with 900 ! I use a 20 tooth Motor Gear so i think it will work !
Stef
Serum
Serum's Avatar
02.07.2007, 05:57 PM
I don't think outrunners are well suited for cars. I don't think they are responsive like inrunners. They are made for a rather set RPM, not for a constant variation.
Sylvester
Sylvester's Avatar
02.07.2007, 06:06 PM
Yea, jhautz said it wasnt the best, he said it felt more like a nitro than a electric.
Losi 8ight e
jnev
jnev's Avatar
02.07.2007, 09:35 PM
Very nice work. Should be a blast!!
