Procharged5.0
Procharged5.0's Avatar
01.24.2007, 09:54 PM
It's not nice to hold out on an RC-M brother! Know what I mean?
hyperasus
hyperasus's Avatar
01.24.2007, 09:56 PM
LOL
Slip me a PM. No one here would notice lol.....
J/K guys.
hyperasus
hyperasus's Avatar
01.24.2007, 10:06 PM
Originally Posted by tom255
I am sitting behind same problem try to find good and cheap UBEC's
http://home.comcast.net/~truerc/esc/escNmotor.htm
If you scroll down yow will see three UBEC's with price aup to $15
Wich one to choose?
3A Ultra BEC Board -exactly same Bec as in ebay link -$12
3A Dynam Ultra BEC Board -$15
3A ASSAN Ultra BEC Board -$10
which one to choose?
Nice find.
The "3A Ultra BEC Board -exactly same Bec as in ebay link $12" looks like the only real choice. The other 2 are Max Input V: 12V ( 3 cells Lipo or 10 Cell). The other one has Max Input V: 35V (8 cells Lipo or 24 Cell Ni-Mh cells)
I'm thinking I'll order 2 of these since they are so cheap.
MetalMan
MetalMan's Avatar
01.24.2007, 11:07 PM
Can't. It's secret :). Hey glassdoc, if you look on the list, mine starts with tc and my first name is Travis. I'm sure you know what I'm talking about :).
glassdoctor
TEAM FUSION
glassdoctor's Avatar
01.25.2007, 11:03 AM
Can you say !@#$!@#%!? oops...
TC, will we get kicked out of here for such behaviour? lol
glassdoctor
TEAM FUSION
01.25.2007, 11:38 AM
Back on topic, I have UBECs from rcmonster, truerc, and an overseas place I can't remember.... the truerc ones were only like 12 bucks or so and work fine.
Procharged5.0
01.25.2007, 04:21 PM
On topic...well sort of..........
How much current does a UBEC need to supply for a hi-torque servo (steering) and a Mamba Max ESC?
Not many servos list current draw. The Mamba Max manual does not list a requirement either.
Mike sent me a BEC from Dimension Engineering and its rated for 1.25A Continuous or 1.5A 60-second peak.
Acceptable or not????
01.25.2007, 04:34 PM
I have this information on my calculations page (in BEC & Wiring):
I hooked up a Hitec HS-5945MG steering servo (180oz-in torque and 0.13 sec speed at 6v) to a Spektrum DX3 receiver and measured the current at 6v under typical use:
  • The Spektrum Receiver uses 0.06A by itself with no servo attached.
  • The servo uses 0.014A when idle (not moving and no load).
  • Under typical steering conditions, the receiver and servo together drew peaks of 2.4A with an average of 0.6A.
Hope this helps to answeer your question...
Procharged5.0
01.25.2007, 04:41 PM
It does.
I have a Futaba 3-Ch receiver. Don't recall the model number but receivers don't draw much current by themselves. I have a 5945MG and a Mamba Max ESC. I think the BEC Mike sent me has too little current capacity. This one has half that of the UBEC. I give Mike a call.
Thanks Brian.
01.25.2007, 04:58 PM
It might work. The peaks were at 2.4A, but the average was at 0.6A. If you use a capacitor on the UBEC, it will really help absorb some of those current transients. A value from 1,000uF to 4,700uF should do nicely. The majority of the current draw is when steering under heavy load. To do this, I had the truck sitting motionless and then manually held the tires somewhat firmly.
Procharged5.0
01.25.2007, 05:01 PM
I sent Mike an email. I'll see what he says...if he'll guarantee it I'll give it a shot.
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
01.25.2007, 06:09 PM
The MM doesn't need a UBEC because it's powered by the battery it's plugged into. :)
As for the 1.25A cont 1.5A peak, I don't think that's enough. If the servo he described was drawing 2A+, then you are going to see slower/weaker response from that servo. IMHO, I'd look for something with more oooooomph.
Sleeb
Procharged5.0
01.25.2007, 06:14 PM
I talked with Mike. It's been resolved quickly and to my TOTAL satisfaction. (Is there any surprise? LOL)
