glassdoctor
TEAM FUSION
glassdoctor's Avatar
01.25.2007, 12:22 PM
Yep... looks like a full race 1:1
Wow, that may be a record for me... reply posted within 1 minute? :)
glassdoctor
TEAM FUSION
01.25.2007, 12:33 PM
:032: :007:
:confused: :confused: :dft004: :dft004: :dft002: :dft002: :p
:rolleyes:
Serum
Serum's Avatar
01.25.2007, 12:38 PM
keep those smileys coming glass..
glassdoctor
TEAM FUSION
01.25.2007, 12:44 PM
I was speechless, lol
Bomb-Proof
01.25.2007, 01:54 PM
lol, thanks guys.
Gettin ready for chroming and powdercoating now.
Serum
Serum's Avatar
01.25.2007, 02:39 PM
And brushless? Hinthint... :p
Bomb-Proof
01.25.2007, 04:29 PM
Nah, this one is gunna stay nitro, but yea there is an electric version in the works. I would like to have a flattrack version in electric. :027:
Serum
Serum's Avatar
01.25.2007, 04:41 PM
Here is somthing to think about; A brushless motor with two shafts sticking out.. One on the end-bell too. Pick the KV you like.. Lehner can make these motors, i had this plan for a monstertruck with a low CG and perfect balanced layout. Only catch with an MT is that the cd is missing..
Bomb-Proof
02.23.2007, 02:44 PM
yep, we were gunna do that at one point, but I think it would snap the shaft fairly easily. I think it would take like a 10mm motor shaft to work.
Serum
Serum's Avatar
02.23.2007, 02:49 PM
We asked lehner about 1 year back about this, and they can produce these motors. No need for a 10mm shaft though.
Bomb-Proof
02.23.2007, 02:57 PM
well I sheered a 6mm shaft off on a whoop section. With no center diff, it takes a major beating.
Serum
Serum's Avatar
02.23.2007, 03:14 PM
what motor/kv/weight vehicle? the shafts are made from hard inox steel, the strains are pretty straight with the cups right onto it. (not sidewards like with gears) if that's the case; You would need 10mm dogbones too, and even thicker ones to the wheels, since the forces are roughly 4 times higher there..
With a normal gear reduction, the motor is spinning at about 35000rpm, and the wheels at about 3000, so the forces at the wheels are 12 times higher than at the shaft of the motor. Since 8 mm shafts are more than enough on the wheels, 8 would be more than enough for a motor.
glassdoctor
TEAM FUSION
02.23.2007, 04:41 PM
A rubber type slip coupler would work great for the driect drive thing. There's a guy on rczone using them in a buggy conversion with direct drive outrunners.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
crazyjr
crazyjr's Avatar
02.24.2007, 12:27 AM
thats a Racers edge .32 right? I got one in an LSP pro-r and its wicked powerful
Bomb-Proof
02.24.2007, 09:11 AM
yep, sure is. :027:
