Serum
Serum's Avatar
02.09.2007, 05:48 AM
I see, that's good, cutting CF wet.
from what i experienced with my lightweight e-maxx, lighter isn't always better.
It helps with getting a more agile acceleration, but it makes the truck less predictable in corners, (if there is a small bump, the light truck respons more to that than a heavier) and more nervous. too light isn't too good either IMO.
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
02.09.2007, 11:01 AM
Originally Posted by AAngel
So...8L on 3S = too much current. I switched back to the 7XL and ran that on 3S with a 16T pinion.
Wow, that's really interesting, and a very valuable data point for me. Looking at the feigao chart, I see the max amps of the 8L is 77A, and the 7XL is 95A. I would have expected completely opposite results of what you got. I'm running a 10L, and I've got good results so far, although I've only pushed it as hard as 13/46 with 12 cells. 15T is in the mail. :)
Now I'm starting to wonder if I should have gone with the XL can instead, if it seems to be drawing *less* current? :032: Maybe someone can straighten out my confusion?
Sleeb
Serum
Serum's Avatar
02.09.2007, 11:06 AM
It works less hard, since its larger.. it's got a lower kv as well, which helps it too.. 8L is one hot motor compared to the 7XL. you can't do anything with the 'max amps' numbers. they are useless, it depends on what vehicle it's used in, and what gearing is used.
neweuser
neweuser's Avatar
02.09.2007, 11:38 AM
I agree with Serum, the xl motors are more efficient. The L cans seem to run hot and can't take as much as far as current. As serum said though, the xl works LESS hard, if that makes sense.
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
02.09.2007, 12:00 PM
makes perfect sence.
lets see:
needed power to move car or truck to 60 kmh in 2.5sec's:
1100watts (not exact, just a guess)
L can motor more maxx power:
1200 watt (again, its an example.)
XL can motor max power:
1500watts.
so L can is working at: 91%
xL can is doing: 73%
of there maximum power.
losi 8ight-t
xray xt8
neweuser
neweuser's Avatar
02.09.2007, 12:42 PM
lets see:
1500watts.
thas is about right.....
jollyjumper
RC-Monster jumper
02.09.2007, 02:37 PM
that's good, i got it about right.
saweet.
losi 8ight-t
xray xt8
AAngel
02.09.2007, 07:25 PM
Yeah, I've gotta tell ya, all of this trial and experimentation is starting to get expensive. I don't know what possessed me to get the 8L. I was thinking, "parking lot" racer.
Oh well, live and learn. When I went back to the 7XL, I didn't loose any speed on the track, temps went down, and I got better runtimes. Go figure. I'm just going to stop thinking about it and stick with the XL motors. The Feigao XL line is enough to satisfy me for now. The only thing I'm waiting for is the MM firmware update. When that comes out, I'm going to grab a Neu 1515 1Y, then that'll be that as far as my motor goes. The only reason I'm considering that is because of the efficiency and cooler running. One less thing to worry about.
