mm is being HORRIBLE -
02.16.2007, 11:50 PM
hey well idk what the hell is wrong but the rusty will cog SO bad it wont move. so i turn the truck off unplug the black wire plug it in and were good to go. but then like 10 seconds later it does the same thing! pretty much when i stop it does it. i was at the track today and couldnt go around one time because of it!!
im not sending it in the cc because last time i did it took over a month to get it back... no thanks...
lmk what i might be able to do to fix it!!
VIDEO!!
http://video.google.com/videouploadf...1e22bab6204d48
TEAM FUSION
02.17.2007, 12:15 AM
Man that's not good... I would check over all the connectors.. maybe resolder anything not factory.
What happens if you reboot without unplugging the black wire? Does it only work again if you unplug/replug this wire?
I wonder if the caps are fried or something is wrong with the motor.
When you plug in the battery, is there a spark? There should be. If there is no spark, the caps are shot.
I don't know man... I have never seen anything like this with the stock setup.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
02.17.2007, 12:18 AM
ill check all that in a sec! on the fone with my g/f... lol
thanks man!
02.17.2007, 12:52 AM
thanks man!
Hold on now! What's more important; your ailing R/C or your G/F? You have your priorities all wrong! :)
That's All Folks!
02.17.2007, 01:54 AM
Try setting the motor timing to "lowest"
02.17.2007, 02:10 AM
lol my g/f always goes number one :005:
its on the lowest right now...
im going to go get some shrink wrap tomorow and make everything tight... i got wires goin everywhere.. hopefully that will help a little!
BMW M Power!
02.17.2007, 02:36 AM
That so NOT racist...(note sarcasm)
That's All Folks!
02.17.2007, 02:59 AM
set it to "normal", run it, then set back to "lowest"
02.17.2007, 03:46 AM
If it was running fine before, messing with the timing isn't going to fix anything. It MIGHT lessen the symptom, but I don't think it will fix the problem. I had a similar problem recently and it turned out that the Deans on my ESC was glazed over. I changed the plug and all was fine again.
02.17.2007, 03:54 AM
well i am changing the deans once i get the shrink wrap tomorow...hopefully that is the problem...
02.17.2007, 03:55 AM
Did you tried another battery pack?
02.17.2007, 03:56 AM
ya they all do it.. the ones with less power (6 cell gp3300s) do it the worst... so idk really what it could be
02.17.2007, 04:03 AM
You have got the LVC disabled? If yes; try enabling it and disabling it again.. Perhaps something is wrong with it...
02.17.2007, 04:05 AM
idk ill check tomorow! bed time for me!!
thanks for all your help guys!
mm is being horrible UPDATE!! vid now! -
02.17.2007, 12:45 PM
hey well i got bored of trying to fix it so i made a vid of what its doing. i think if i got rid of those wire things and either A. just soldered together the wire so it could never malfuntion. or B. i put another plug on there... that better not void cc warranty....
well the video is uploading..... ill edit this post as soon as it gets done!
ok video time!!!
Linear Mode
