03.29.2007, 11:56 PM
The rear diff post size (the part that the cup is hooked to) is 5mm on the CRT.5, while 1/8th scale posts are 8mm...
andywpj
03.30.2007, 03:15 AM
i don't understand why not try 5mm shaft motor with steel motor gear?
03.30.2007, 09:59 AM
Well, there have been a number of people who have tried it and the pinion doesn't last long at all despite the fact it is hardened steel. Read this thread for more information; RCM Mike even has his take on them.
andywpj
03.30.2007, 10:54 AM
ok, i think that is not a problem.
pinion gear maybe try use like SCM-21 steel materials with "Heat Treatment" process.
we have alot people convert X1CRT to BL with stock steel spur not problem.
gear not eat and great.
it's look like
Here is some driver CRT stock gear clip.
http://www.youtube.com/watch?v=sajULgawAgo
so i think maybe gear is not a problem , this CRT.5 can more easy to convert right?
03.30.2007, 11:49 AM
Yes, it would be much easier to convert. :)
I've been talking to Mike (owner) and we've been throwing ideas back and forth, so there IS a solution. I just want to find the "right" one.
Patrick
Patrick's Avatar
03.31.2007, 12:00 AM
That backflip on flat ground was pretty impressive.
skellyo
skellyo's Avatar
03.31.2007, 12:11 AM
Huh?
Patrick
Patrick's Avatar
03.31.2007, 12:53 AM
In andywpj's youtube video that he linked to (post #154), one of the cars does a wheel stand which ends up being a full backflip, I don't think I've seen that before.
BP-Revo
BMW M Power!
BP-Revo's Avatar
03.31.2007, 01:38 AM
They were speaking Chinese (I'm 1/2 Chinese, and can speak Mandarin fluently). The last 10 seconds or so the camera guy is saying "one more time" in reference to the backflip. :)
Looks pretty awesome. I'm hoping my .5 will do the same.
Anyone happen to know the inner diameter for the bearing used on a standard 1/8 scale center diff?
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.31.2007, 10:12 AM
Not sure about the bearing...
What I am sure about is that those trucks in the video had spooled center diffs and kinda low gearing... man tha thing was super punchy.. but no much on top
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
glassdoctor
TEAM FUSION
03.31.2007, 10:29 AM
Looky what me seee.... :004:
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Sylvester
Sylvester's Avatar
03.31.2007, 10:33 AM
Damn GD, where was that?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
riceman
RC-Monster Gold
riceman's Avatar
03.31.2007, 10:43 AM
Look at the trash can. It says "FAIRPLEX" which would mean RCX! I wonder how long those will last.
glassdoctor
TEAM FUSION
03.31.2007, 10:47 AM
yep... rcx good sleuth work :)
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
MetalMan
MetalMan's Avatar
03.31.2007, 11:10 AM
1/8 buggies/truggies use mostly 8x16mm bearings all around. The center diff is no exception :).
And I should be seeing some in person tomorrow ;). Same with BP-Revo.
