Flextek Arms -Advice Wanted-
GorillaMaxx360
GorillaMaxx360's Avatar
Flextek Arms -Advice Wanted- - 04.02.2007, 09:30 PM
OK guys i have these Flextek arms (maxx arms) sitting around and they are bothering me in 2 ways. The first way is that they are very sloppy as far as movement. the wiggle all around due to the bad spacer design. Second because of the thicker width of the arm. The shocks bind because they are going out from top to bottom because the shock standoffs do not line up with the lower shock mounts (on arms they are flared out more and out of line). This creates friction on the shocks and makes them compress very hard because the shock shafts are not exactly straight up they are slightly curved. I am using FLM shock towers and standoffs, FLM hybrid bulks, big bore shocks, and sliders. Can anyone help me with these problems. Thanks
(i heard that daf has made some custom arm spacers for better performance how can i make or buy these and will they help)
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.02.2007, 09:33 PM
Why are you posting this in Brushless area? There is a 'Flextek' thread, try it.
t-maxxracer32
t-maxxracer32's Avatar
04.02.2007, 09:39 PM
probably because alot more people view this section... even though its not really in the right one...
GorillaMaxx360
04.02.2007, 09:53 PM
I posted here because there is a lot more trafic here. More people read about brushless than they do flextek stuff. More people = more advice
Dafni
Dafni's Avatar
04.03.2007, 02:25 AM
Could you solve the shock-rubbing issue with some extra stand-offs??
GorillaMaxx360
04.03.2007, 07:52 AM
i could yes but i do not know for sure if the other standoffs would be longer. I have tried to throw some shims between the standoffs to allow for the shocks to stand out more, but i can only get 2 shims in there becasuse the nut is not that long. What do you think about the spacers issue?
neweuser
neweuser's Avatar
04.03.2007, 11:10 AM
You could also try longer screws so the spacers would work?
Serum
Serum's Avatar
04.03.2007, 11:27 AM
Yeah, i am using homemade spacers on mine. I am using 1/8th thick titanium shocktowers, which make the off-set even bigger.
I used rather large aluminum spacers/UE stand-offs
I emailed them at flextek, but they played the killed innocence.. I was the absolute first in the world who contacted them about the sloppiness and the poor quality of their worthless bushings. It must had been something with burrs on either the aluminum bulks or their titanium arms.. Right....
neweuser
neweuser's Avatar
04.03.2007, 11:36 AM
I thought they had good customer service? Or at least I remember hearing that somewhere????? That is too bad....
zeropointbug
Z-Pinch racer
04.04.2007, 12:23 AM
You willing to sell those Flextek's Gorillamaxx360 for a deal? :027:
neweuser
neweuser's Avatar
04.04.2007, 09:15 AM
I think if you use some thinking, you will figure out the issues like Serum had done. I'm sure the arms are nice, but not everything comes without some thinking to it....try Serums idea and see what you can do. That's my opinion. I would not sell them though....
GorillaMaxx360
04.04.2007, 05:11 PM
you are right i have indeed figured out a way for them to work. It is way better than the first time i tryed it, the smoothness of the arms i mean. But put it this way there is a tiny bit more smoothness to the plastic arms than there are to the ti ones. But for racing and bashing i do not think this difference will make a difference. It compresses different than the plastic arms with same shocks, but then again i can not get acurate compression ratios. I can not do this because the shock positions on the ti arms are in different places than on the plastic arms. This will make the ti arms either feel softer (shock motion) or harder to compress than the stocks because of there different shock angles. But i do not beleve that this should make a difference. The only reason i am selling them is because of there look and that they dont match my machined maxx and they get dirty easy. But i will get over that. SO i am going to my LHS and i willl talk to the guy that is going to buy them if he can get me what i want i will get rid of them if not i will keep them. I will probably keep them though because i am kindof attached to them and if i decide to use different arms anyway it will not hurt me to leave them lying around anyway.
zeropointbug
Z-Pinch racer
04.04.2007, 05:26 PM
Im curious now, what would you be willing to part them at what cost? Let me know.
Zero
GorillaMaxx360
04.04.2007, 05:30 PM
$200
zeropointbug
Z-Pinch racer
04.04.2007, 05:39 PM
What kind of condition are they in? If they are in mint, i'll think about it.
About the 'slack', is this an axial movement, or just plain loose?
