What tape to use to control tire swell? -
04.08.2007, 12:01 AM
What is the best tape to use for tires. I just did a set for my rustler using some duct tape. Worked for a minute but then my good ol Lehner managed to break the tape loose and the tires instantly started ballooning like mad. I even went threw the trouble of cleaning the tires with alcohol just to make sure the tape would stick good. Does anyone know which tape will stick like grim death? With my bigger monster truck tires I haven't had this problem, but my new street rusty goes like a scalded cat so I need these wheels to be able to handle the RPM's.
Oh and btw this was on a pair of Pro-Line Dirt Hawg II.
Z-Pinch racer
04.08.2007, 12:12 AM
You wouldn't be willing to do an experiment would you?! :027:
I have a great idea of using some kind of fiber mesh, and using CA glue on the inside of the tire. This would create a bulletproof, high performance tire!
I would have done it, but I thought of it AFTER I glued my tires... :002:
I personally never used duct tape, and I never thought it would even hold anyways, IMO.
RC-Monster Dual Brushless!
04.08.2007, 12:14 AM
The duct tape should work. You usualy need to go around twice though. Did You?
Z-Pinch racer
04.08.2007, 12:15 AM
Why would going around twice help it? It's not getting any more surface grip than once around.
TEAM FUSION
04.08.2007, 12:23 AM
I have heard the Gorilla brand duct tape is awesome... so that may be worth a try.
Something I have thought about doing with my street tread tires... is wrapping a durable thread around the outside of the tire in the center groove. Wrap it several times... with the ends of the string glued. That would create a belted tire without having to get inside it.
A heavy thread/light string of some kind would work fine imo.... I will do it on my xxcr buggy sometime...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
04.08.2007, 12:36 AM
I only went around once dangit. I do have some gorilla tape but I didn't use it because it is alot stiffer then regular duct tape. I'll buy another pair of wheels and tires from my lhs on Monday and try going around twice with the tape. Really is a pain flushing down $30 every time a set of tires doesn't work out.
RC-MONSTER BRUSHLESS FANATIC
04.08.2007, 05:37 AM
I just use duct tape went around once only and it is working fine ,it really does the trick of preventing the tires from ballooning
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
Hyper 7 Erevo Center Diff
04.08.2007, 08:41 AM
I use package strapping tape...the kind with the little fibres in it...I think that is what it is...and i went once around and it is fine
Z-Pinch racer
04.08.2007, 02:39 PM
Yah, that packing tape with fiber in it seems like it would work the best to me. It sticks very well.
Glassdoctor: To me, one thread in the center of the outside of the tire would make two (smaller) balloons, don't you think?
When I need new tires, I am going to try some fiber mesh with CA glue, or some glue that bonds very well to rubber.
TEAM FUSION
04.08.2007, 03:12 PM
Yeah... maybe. Depends on the tire and speed I think. It will be much harder for a narrow section of tire to balloon than the whole thing.
Maybe two "belts" would do it on a bigger tire.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
04.08.2007, 03:15 PM
Maybe tire manufacturers should wake up and mold in some fibers right from the factory! This issues isn't exactly new...
04.08.2007, 03:16 PM
somebody once told me to use strapping or belting tape it was a black like tape does anybody know of this
Z-Pinch racer
04.08.2007, 03:27 PM
GM360, no i don't think i've heard of that?
GD, i think it would still balloon though, just two smaller ones, about half the swelling.
And yes, I've said that many times, these tires NEED to come from the factory WITH fiber belting inside the rubber. They would be a lot better performing, and takes some variables from speed calculating, along with less power for a given speed.
Maybe, I'll try this and make after market modded tires for purchase? :027:
04.08.2007, 10:58 PM
Actually, the Proline MTR tires have internal ribbing that seems like it should reduce ballooning. My Revo has not noticed a difference in ballooning between these tires and non-MTR tires :mad:1.
04.08.2007, 11:03 PM
Yeah, they ought to mold in fiber "circles" so they don't expand at all. Ribbing helps, but the centrifugal force apparently easily overcomes the ribbing...
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
