My CRT.5 conversion
IBJAMMIN
IBJAMMIN's Avatar
Talking My CRT.5 conversion - 04.14.2007, 07:57 PM
Well I see there is a couple of CRT.5 conversion projects going on here this is what I have came up with. I wanted a car to run the Mamba max motors I have and once I saw the CRT.5 I new it would be perfect with 1/8th scale diff gears and suspension design in a 1/12th scale car it should be a great platform for brushless motors. :)
I have a 5700kv Mamba and decided to go with a 3s 4000hv Maxamps lipo pack to keep the weight down looking at the numbers 50-60mph should be posible and the weight is right at 4lbs.
I went with the Kyosho 46t spur to keep the pinions reliable I stole some parts off my full size CRT the rear aluminum diff mount and drive cup and pin for the diff gear along with the front center shaft off my HPI savage. I also moved the center diff over to the right side of the chassis to get the battery closer to the centerline and also allow more room for a 4-5s pack later.:)
Name:	e crt 039.jpg
ID:	2744   Click image for larger version
Name:	e crt 040.jpg
ID:	2745   Click image for larger version
Name:	e crt 032.jpg
cadima
04.14.2007, 08:56 PM
nice truck Jammin. Where's the ESC?
GorillaMaxx360
GorillaMaxx360's Avatar
04.14.2007, 09:01 PM
NIce man i like the .5
jnev
jnev's Avatar
04.15.2007, 03:19 AM
Very nice!! Looks really clean and ncie set up. Should fly on 3s... :027: .
Where will you mount the esc, doesn't seem to be much more room left.
Sylvester
Sylvester's Avatar
04.15.2007, 11:24 AM
How did you fit the kyosho spur gear on there?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
IBJAMMIN
IBJAMMIN's Avatar
04.15.2007, 04:36 PM
The Kyosho spur bolts right up to the CRT.5 diff the only problem is the bearings. Check out RICEMANS post in the brushless section for the details on how to install the Kyosho spur to the CRT.5 diff. Here is a pic of the parts side by side you can see the diference in bearing sizes.
I'm working on the ESC mount now it's going to end up just above the motor in the center of the chassis. :)
Name:	e crt 056.jpg
ID:	2762   Click image for larger version
gizzmo79
04.15.2007, 05:28 PM
Hi nice truck
Where did you get the motor mount and the battery mount? What kinde of pitch is it on the kyosho spur
Sorry the bad english i'm from Norway
andywpj
04.15.2007, 08:50 PM
in the future (as soon), Jammin ofna maybe consider E-CRT or E-CRT.5 Version.
this is i know news.
IBJAMMIN
IBJAMMIN's Avatar
04.16.2007, 03:19 AM
IT'S ALIVE
I just got it done to late to drive it but everything works. :018:
I used the ESC off my CRT so the UBEC was wired in so I decided to leave it makes it easier if I want to play with a 4s lipo later and I like the extra voltage to the servo.
Anyone thinking about this conversion you can probably use the RC Monster motor mount for the Jammin buggy to convert it with a couple of washers under the front diff mount to level out the center diff it will make it alot easier to get the motor mounted up. :)
Name:	e crt 096.jpg
ID:	2769   Click image for larger version
Name:	e crt 098.jpg
ID:	2770   Click image for larger version
Name:	e crt 099.jpg
Sylvester
Sylvester's Avatar
04.16.2007, 03:22 PM
Did you use the CRT mount that mike sells?
Losi 8ight e
neweuser
neweuser's Avatar
04.16.2007, 03:38 PM
Everything looks great. Glad to see you here. :)
riceman
RC-Monster Gold
riceman's Avatar
04.16.2007, 06:16 PM
Hey this one looks great. Nice and clean.
IBJAMMIN
IBJAMMIN's Avatar
04.16.2007, 08:48 PM
Thanks this thing is a rocket on 3s I had a chance to run a few packs today and play around with the ESC to get the power to the ground. Temps were right around 140deg in the motor and ESC the battery started to get warm also whitch was strange? It got up to about 120deg when I was running in the grass to see how everything would do with a load.
I made my own mount but used a jammin buggy aluminum center diff mount so with Mikes Jammin buggy mount I think the conversion will be alot easier to do with the Kyosho spur. :)
jnev
jnev's Avatar
04.16.2007, 08:56 PM
Looks awesome. Try to get some video, will you. All these crt.5's popping up, now makes me want to convert one.
IBJAMMIN
IBJAMMIN's Avatar
04.17.2007, 12:10 AM
Here's a vid I put on youtube www.YOUTUBE.com/watch?v=DnD6DVYfx2A
