Lipos for Brushless -
07.03.2005, 11:32 PM
I am sure this has been asked several times ragarding other vehicles, sorry, but i need to ask for my application. I am running 2 t4's. One has the novak 5800, the other has the mgm80 and 6s motor. Is there a good lipo pack that i can use with both? if not, what would be the best pack to match up to the mgm/6s combo? and finally, where is the best place to get some lipos?
thanks
S^3: everyone wishes they could design modifications like these.
07.04.2005, 03:09 AM
The best lipolys to get for the 6S are the kokams 3200's. i don't know what you are looking for in speed, but a 2S runs pretty quick allready. those kokams can deliver a 64A.
Site Owner
07.04.2005, 09:50 AM
Agreed. The packsa mentioned will work well in either application.
RC-Monster England!
07.04.2005, 10:18 AM
The Kokam's are really the only cell you want to use in either, I think it has a built in cut off device? You need one either built in or inline to run lipo with the Novak safely. The 6s draws a lot of amps as well so don't cheap out on lipo's otherwise you risk damaging them. Word has it 2s lipo is about the same power as 7 nimh due to less voltage drop, less weight etc.
07.04.2005, 10:34 AM
The Scorpion packs have the cutoff.
07.04.2005, 10:45 AM
i am looking to get 60 out of my modified t4.(it has the 6s). i am currently getting 50 with an 8 cell pack of gp3300's.
Site Owner
07.04.2005, 10:58 AM
3s Lipo or a taller gearing will get you to 60.
RC-Monster England!
07.04.2005, 11:53 AM
I have a Mtroniks plasma pro motor which is fairly similar to the 540 6s, on 8 cells with steep gearing it'll pull 60mph off easy enough, on 6 cells if you gear steep it'll just about hit 50mph in my TC3. In my T3 I've only ran brushless with Masher 2K tyres which slow it down a lot because the extra weight compared to normal size tyres, but on 8 cells its still game for 50mph wheelieing all the way there. But battery life takes quite a hit (not so much with 8 cells).
07.04.2005, 10:56 PM
well i think i may try and get a 2s pack with the 20c discharge rate to try it out.
RC-Monster Captain
07.04.2005, 11:48 PM
I dont know, but using lipolies with the novak setup is a bit risky.
Nice to meet you!
RC-Monster England!
07.05.2005, 06:56 AM
As long as you get some sort of inline voltage cut off designed for 2s lipo it'll work fine.
07.05.2005, 12:40 PM
i do plan on getting a cutoff. any expectations on speed for the mgm and 6s with a 2s pack and geared with a 31/104 ratio with road rage2 tires?
thanks
oh yeah, what about a polyquest 2s pack, any thoughts? some ppl recommend those also
07.07.2005, 08:21 PM
anybody know? or have a guess?
07.07.2005, 08:32 PM
Which one? (How many mAh?)
07.07.2005, 11:32 PM
estimated speed with a kokam 2s 20c discharge 3200mah pack?
is polyquest a good pack
and a new question is do i need the voltage gaurd thing for charging and the one for low voltage cutoff for in the truck?
thanks
