Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
Serum
Serum's Avatar
05.15.2007, 03:40 PM
For 4S a 2200Kv would be an okay choice as well!
jhautz
jhautz's Avatar
05.16.2007, 03:35 AM
Mike runs the 1515/1Y on 4s in his Maxx. It runs really nice.
to make it...
or break it...
Silent...But Deadly
ssspconcepts
ssspconcepts's Avatar
05.16.2007, 07:37 AM
I will be running 5S. By the way...I see an awful lot of traffic in the forums regarding problems associated with the Quark 125. I think I have all my bases covered and should be fine, but would you guys please give me one last sanity check? Also note that my maxx is a heavier truck....
I'll be running:
  • Quark 125 with heat sink and two fans
  • Dimension Engineering Sport BEC
  • Neu 1515 2.5d/F motor
  • Evo 25 5000 mah 5s1p Lipo
  • Lightning Stadium Pro 1/8 scale diff gears
  • 5.5" tires
  • 72T 32P spur gear
  • 16T 32P pinion gear
If my research is correct, everything should run cool as a cucumber.
neweuser
neweuser's Avatar
05.16.2007, 09:04 AM
Looks good. I run 4s on the 1515 1/y and it works real good. Keeps my esc at low temps and the motor barely gets hot. I also have run it on 5s at times too, gets a little warm for my liking though, but that 5s really screams!!!!!!!
AAngel
05.16.2007, 01:24 PM
Just make sure that you do something to bleed the heat away from the Quark. Most use a combination of the RC Monster heatsink and fans. I just mounted mine on a piece of 1/4" thick aluminum that was mounted to the chassis, effectively making my whole chassis a heatsink. I didn't use any fans, but it seemed to be working. I did't get to run my Quark for long though. I had to send it in.
ssspconcepts
05.16.2007, 02:33 PM
What happened to it?
AAngel
05.16.2007, 02:37 PM
I was a defective unit. I don't think I ran it enough to break it. I sent it to them on Monday and haven't heard anything yet. I don't even know if they will warranty it, because I told them that I was running it in an 8ight; and the guy I talked to seemed to be big on reminding me that the Monster Pro is not designed for 1/8 scale applications. I'll have to see.
I've been having a bad run of luck with equipment lately, so you really shouldn't consider my experiences as typical. MANY are running the Quark in their conversions and have had no problems, as long as they took care of the heat.
ssspconcepts
05.16.2007, 05:29 PM
Well, sorry to hear about your problems....I read and learn...that's what these forums are all about. Thanks.
neweuser
neweuser's Avatar
05.16.2007, 05:32 PM
Then why in the heck would they rate it for 6s??????????? you certainly would not run 6s in an RC18T!!!! Maybe he had no idea what the heck he was talking about. I think some run it 1/8th scale don't they from here?
ssspconcepts
Thanks. What gets hot when you run 5s on your quark?
Battery?
Motor?
ESC?
neweuser
neweuser's Avatar
05.16.2007, 05:39 PM
Battery?
Motor?
ESC?
the rear 3 wires, and the one side of the quark, easiest way to describe it is the side that the batt wires on on. It's not terribly hot though, more than my 4s is...but my kv is 2200 on the motor as well, so if you had a lower kv, the temp would be better I would think.
ssspconcepts
05.16.2007, 06:42 PM
Sorry for all the questions...but are you running the RC Monster Heatsink and fans?
AAngel
05.16.2007, 11:31 PM
If the side with the batt wires is heating up, the source of the extra heat is likely the capacitors. Even the guys at S&T will recommend that you add extra capacitors to the Quark when running it in a large scale truck. When I called about my setup, running 5S with an 8XL, Frank said that extra caps are very much recommended and the more the merrier. Since I've added the extra caps to my MM and Quark speed controllers, they do run significantly cooler. The MM is also handling gearing that it wouldn't handle before without cogging.
Here is a pic of the first cap bank that I made, wired to a MM.
ssspconcepts
05.17.2007, 09:08 AM
[QUOTE=AAngel]If the side with the batt wires is heating up, the source of the extra heat is likely the capacitors. Even the guys at S&T will recommend that you add extra capacitors to the Quark when running it in a large scale truck. When I called about my setup, running 5S with an 8XL, Frank said that extra caps are very much recommended and the more the merrier. Since I've added the extra caps to my MM and Quark speed controllers, they do run significantly cooler. The MM is also handling gearing that it wouldn't handle before without cogging.
Hmmm...my hats off to you for figuring out how to add all those capacitors. I am not afraid of performing custom mods to my trucks, but I just don't think it should be necessary (adding capacitors). I have several CC speed controls and have never had any problems...but then again I don't push them to the limit either. However, I have talked to Bernie at Castle a number of times and he always has a professional answer for me and I always walk away amazed that their products perform better than what their specifications indicate.
The Quark 125 is my first S&T product. The gripe I am building to is this...Why on earth would an company rate an ESC at 6S and tell you to add capacitors? That's crap.:mad:1 I'd rather build my own from the ground up.
neweuser
neweuser's Avatar
05.17.2007, 09:17 AM
Here is what I run on mine.
http://i56.photobucket.com/albums/g1...r/PC281266.jpg
http://i56.photobucket.com/albums/g1...r/PC281258.jpg
http://i56.photobucket.com/albums/g1...r/P1021284.jpg
No prob on all the questions, better to ask now then "poooooof" later! LOL
