padailey
06.19.2007, 11:50 PM
And a few more.....
ID:	3113   Click image for larger version
ID:	3114   Click image for larger version
bdebde
That's All Folks!
bdebde's Avatar
06.20.2007, 02:07 AM
I like that "electric $0.00 per gallon", that's great.
padailey
06.20.2007, 10:38 AM
Thanks.... I had to have a little fun with it!
padailey
06.20.2007, 12:49 PM
Got a question on my motor.... It came in a Feigao box with a Feigao sticker on it but it's blue... I thought the Nemesis were blue? Just trying to get more educated!!
06.20.2007, 12:50 PM
The Wanderers are blue too. Maybe they changed the color?
padailey
06.20.2007, 12:55 PM
Maybe they did and are using up the old stock of boxes!?! lol The picture on the box is purple with three different colored wires.... the actual motor is blue with all blue wires. Hmmmmm.........
jnev
jnev's Avatar
06.20.2007, 01:27 PM
I had the exact same thing... 3 blue wires, and a blue can. But I don't mind because it works awesome!!:027:
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
06.20.2007, 05:17 PM
The nemesis series motors are also feigao, simply a different color. I wouldn't worry too much. Even the wanderers are only slightly updated Feigaos, so either way you're set.
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
bdebde
That's All Folks!
bdebde's Avatar
06.20.2007, 09:22 PM
My last 8XL was blue with the blue wires. I even had blue heatshrink the same color on the connectors. I also noticed that the ends of the can were dimpled (unlike my 7XL), likely to help retain the endbells better.
padailey
06.22.2007, 10:48 AM
Yep mine has the dimples also... I'm not worried either cause it does work great I was just wondering.
I've been having some issues with my suspension.... not sure if it's cause its a little heavy or its something else but it just doesn't rebound well and tends to bottom out a little more than I'd like. I'm gonna try going about as stiff as I can and see what happens.
06.22.2007, 01:20 PM
Even with the "dimples", the end plate still comes off fairly easily. I would definitely still use some type of clamp and/or support the rear of the motor.
padailey
06.22.2007, 01:58 PM
I'm working on that... The motor is supported underneath by the old nitro motor mounts. As I've adjusted some things around they don't work as well as they did when I first got it together but there is some support there. I thought I had something figured to clamp the motor to the mounts and hold the motor together but it just didn't work out so I'm back to the drawing board. I have another idea but haven't gotten it worked out yet.
bdebde
That's All Folks!
bdebde's Avatar
06.22.2007, 03:15 PM
If running the RC-Monster heatsink, just use a piece of aluminum angle on the back part where it clamps and attach to chassis. That is what I did when I ran XL motors in my buggy.
padailey
06.22.2007, 03:40 PM
Where is everyone getting this aluminum angle? I found a place online www.onlinemetals.com but I'd rather get something locally so I can get what I need rather than re-order more when I screw up! lol
06.22.2007, 05:51 PM
Just order a foot or so. That way you have extra to play with.
