Originally Posted by BrianG
I use regular flat paint as a primer (regular primer doesn't stick as well for some reason),
You are exactly right about that. I only know of one primer that is specifically made for AL, and it doesnt come in a spray can as far as I know. The best route for painting aluminum is to scotch brite it as best you can, then clean it thoroughly with Denatured Alcohol, and prime with a flat paint.
