has anyone used the new software for their mamba max?
Mr.lst
has anyone used the new software for their mamba max? - 09.02.2007, 05:10 AM
I am a little concerned with downloading the new software because of the problems castle had last time. If anyone has used it let me know if you have had any trouble. thanks
jhautz
jhautz's Avatar
09.02.2007, 10:30 AM
what version is the new version?
I recently went to v1.09 with no issues. Is that the new software your talking about?
to make it...
or break it...
Silent...But Deadly
Tazz
Custom
09.02.2007, 10:34 AM
I am still using the 2.20 version. When I went to the 3.0 version it installed fine but would not recognize any of my esc's so I went back to the 2.20 ver. and everything has worked fine.
jhautz
jhautz's Avatar
09.02.2007, 10:41 AM
Oh the Castle link software. Ive been using 3.0. No problems.
to make it...
or break it...
Silent...But Deadly
gasshead
j-womp
gasshead's Avatar
09.02.2007, 12:36 PM
i have also been usein the 3.0 version with out problems, but i need to buy another link to use with my ccbec...
  Send a message via AIM to gasshead
wallot
wallot's Avatar
09.02.2007, 03:42 PM
i did have problem when i did just upgrade. after i uninstalled everything and cleaned up registry and then installed version 3.0 no problems at all
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
09.02.2007, 09:20 PM
I could not get 3.0 to work with windows Vista. But 2.0 works with no problem.
squeeforever
squeeforever's Avatar
09.02.2007, 10:27 PM
Anyone have any idea why the computer doesn't recognize mine? I have XP and the 1.0 CD. I install it, it won't recognize the MM. I then updated it to 3.0, then it still wouldn't. It did when I first got it from from a friend, but when I was adjusting things, I updated the software on it and it never recognized it again. It won't work in the truck either. Anyone ever have this problem?
E-Maxx King
09.03.2007, 01:58 AM
Did you install it right? Cause I had to go into to my control panel to install it right. I think.
http://www.castlecreations.com/suppo...e_link_ts.html
crazyjr
crazyjr's Avatar
09.03.2007, 02:29 AM
Mine worked with no problems, I downloaded from site on my laptop and no problems
Hickoryhead
RC Wanna BE
09.03.2007, 04:57 AM
I can't remember where I read it but I read that XP works best with 3.0. Vista with 2.0. Not sure where I read it but I have the 2.0 CD. I installed in on 2 different Sony Laptops. 2.0 would not see the ESC but would open with XP. When it opened up the first time it asked to update the software. I did and things worked after that on that laptop. I did the same on my new laptop with Vista. I tried to open the link for the software and a window poped up stating there was an installment problem after I upgraded. I uninstalled all the software from the laptop and reinstalled the CD with 2.0. After I reinstalled it I declined the update. Works perfectly. You might want to find some one in your area or your LHS to see if there is a 2.0 disk some one has for you to borrow. If 1.0 and 3.0 are not working I would say try 2.0. If that fails call Castle directly. It would be a ESC USB problem at that point.
crazyjr
crazyjr's Avatar
09.03.2007, 11:31 AM
With My home computer i just updated when prompted to and it works fine. with my laptop, i needed to download .net something and it works fine
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
09.04.2007, 08:21 AM
Zero problems with 3.0
DickyT
09.04.2007, 08:35 AM
I run 3.0 on XP Pro SP2 and Vista, both without issue.
hyperasus
hyperasus's Avatar
09.05.2007, 02:49 PM
Does 3.0 work with Vista 64bit now?
