What bl-motor for a hbx-crosstiger truck ?
speedy
What bl-motor for a hbx-crosstiger truck ? - 09.21.2007, 03:54 PM
Hi !
I'd lika a mild bl-setup for my hbx crosstiger truck (simular to wilddagger ! )
I'm goung to run int om 6-8cells nimh and 2s lipo :)
Do you guy's know how many amps a stocj mabuci 550 motor pulls och 2s lipo
http://http://www.emrichs.de/auto/hbx/bonzer-leicht.jpg
09.21.2007, 05:46 PM
Got a pic of this truck, might help deciding based on space available/balance.
speedy
09.22.2007, 05:10 AM
Hi !
Sorry idon't have any pic,s but i know that i can only fit 3st pinion gears 19,21 and 23t . I can modify the battery mount to fit any batterypack !!
miniGranis
09.22.2007, 02:31 PM
You will find pics here:
http://www.emrichs.de/auto/hbx/index.htm
09.22.2007, 05:27 PM
Oh, that thing. I've seen them advertised on ebay- not the best quality truck to be brutally honest, you'd have been better off buying a wild-dagger or something similar from a big name company. Anyway, I would go very carefully about putting a BL motor setup into it, chances are the drive train will fly apart and there are no 'upgrade' parts that I know of, only replacements. Better off getting a more powerful brushed motor like a titan 550 or something like that.
speedy
09.23.2007, 04:09 AM
i know it's not the best rc truck in the world but i think it coud handle a milder bl-set-up !
because the drivetrain is kind of strong
maybe a feigao 10s ?
09.23.2007, 09:29 AM
Hmm, going by some english specs I found it only weighs about 1.1kg/2.5lbs? If that is anything near correct, then an S can BL motor would be plenty of power.Just match the number of turns to the voltage you plan to use, and aim for about 30-35,000 rpm & 35mph. I could be completely wrong and it turns out to be a tough little bugger. An MM esc would go well with that motor too.
http://www.gems-of-time.co.uk/nitrotek/7.html Specs
speedy
09.23.2007, 02:32 PM
Yes i think that spec are correct ! :) This truck is light ! and wil be even lighter if i get som lipopacks for it :)
