Trinity duo
ib4200
nota newb
ib4200's Avatar
Trinity duo - 11.17.2007, 11:58 PM
anybody know how many cells the 550 sized duo's can run on? it only says its for the emaxx but other than that i dont see anything else that says it can be used on more than 12
  Send a message via AIM to ib4200
11.18.2007, 05:38 PM
Holy flying monkeys batman, I like the look of those ALOT! As for voltage/cell count- you would base it on the kv rating/number of turns. Basically whatever cell count/voltage you can run that wont exceed about 40-45,000 rpms maximum ideally. I would really like to know more info about those 550 sized duo motors, especially kv ratings and magnet size; knowing its sensored though is a very good start.
EDIT: 12-13mm rotors... about the same size as the HvMaxx motors. Hmm, disappointed now.
ib4200
nota newb
ib4200's Avatar
11.18.2007, 09:39 PM
yeah i like them sofar too. my hvmaxx motor is fried but i still have the working esc. it looks like they are cheaper than the novak motor too.
11.19.2007, 07:56 PM
The only other option, since you have the esc working, is the crazy 7-8XL mod. You use the Hvmaxx as the sensor, and plug in the sensor wires to the esc, then wire a feigao to the power wires. The critical thing is syncronising the motors, by rotating the feigao rotor by hand until the magnet is 'matching' the hvmaxx motors magent position.... its really rather complicated, and Im rather fearful of trying it, but if you get it right, the results are great apparently. Personally, i'd just buy another sensored motor that the esc can handle.
ib4200
nota newb
ib4200's Avatar
11.19.2007, 09:13 PM
what other motors can i buy that will work. i might just wait for the duo to come out. if it works then great! but if its not fast enough then im sure i'll find somewhere to put it. maybe i'll make my xxxnt duo powered
11.20.2007, 07:04 PM
In all honesty there are precious few larger sensored motors around. Aveox sell them, but they cost more than 2 hvmaxx motors put together (quality is very high though)- not sure whether they would work with hvmaxx esc though. Feigao sell XL can sensored motors too believe it or not, but they are special order items- GriffinRU knows much more than I do about them; the sensor wires need to be re-arranged though since the phases fire in a different order or something like that. The duo looks like the best bet, provided the sensor wires are in the correct order and you can make/buy a doubled ended cable from Novak (sure they sell them)- for the price they look okay, and they have a built in fan for extra cooling, which is always good.
ib4200
nota newb
ib4200's Avatar
11.23.2007, 12:07 AM
novak and trinity both sell the cables
