What controller should I use?
Todd85VT
What controller should I use? - 01.01.2008, 09:09 PM
Hello everyone. I just bought an e-maxx 3905 and Im going brushless. I have a Nemesis Blue 11XL motor. I am planning on running my setup w/ 6s lipo (two
3s packs wired in series). My question is what controller should I get, either a Quark Monster Pro 125b or a MGM Compro 16018. I really like the fact that the Quark is very smooth so I've heard but I know it can be trouble on 6s lipo. The MGM sounds good except for it going into reverse at slow speeds instead of the brakes. Should I get a different motor altogether and run 5s w/ the Quark or run 6s w/ the MGM and the 11XL I already have? Also, how does the MGM perform on 6s? If anybody can give some ideas/opinions form experience it will be greatly appreciated. Thanks,
Todd
tashpop
01.01.2008, 09:19 PM
i just got a mgm and i'm running 6 cell a123. a little bit less voltage, but its doing fine. i haven't had any of the reverse problems at all. the only thing i haven't worked out yet is my breaks at high speeds. i haven't turned them up much, but at the present setting the faster i'm going the less it breaks, although the breaks get progressively stronger as i slow down.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
Todd85VT
01.01.2008, 09:35 PM
So do you think 6s on the MGM16018 with an 11XL would be a good setup for my new Maxx? I just don't want to spend loads of money on a setup and not be happy with it.
GorillaMaxx360
GorillaMaxx360's Avatar
01.01.2008, 09:53 PM
i do not no much about the MGMs, but i do know that a lot of quarks do not like to work with 6s even though quark says it can work with 6s.
Patrick
Patrick's Avatar
01.01.2008, 10:46 PM
Some quarks do work on 6s (like mine), others have had problems.
The 11xl should be good on 6s.
Todd85VT
01.03.2008, 02:19 AM
So the MGM Compro 16018 should run fine on 6s lipo with an 11XL? Anything I should be aware of before buying that controller?
