4 pole motors
4 pole motors - 01.03.2008, 11:34 AM
are there any 4 pole motors besides the expensive neus, lehners, and plette's, i'm told my 18.97 is a good match for a 4 pole
starscream
RC-Monster TQ
starscream's Avatar
01.03.2008, 12:38 PM
I'm not aware of other 4 polers but Mega Motors makes great 6 pole motors.
Ha Ha
Serum
Serum's Avatar
01.03.2008, 01:59 PM
I think that covered the largest pile of 4 polers.
it's not that the schulze is a good match for a 4pole, it's just that it's one of the few controllers that can handle them. it also depends on the type of 4 pole though. the schulze accepts pretty much any motor. (before it eventually lets out its famous blue cloud)
david lamontagn
01.03.2008, 02:24 PM
MGM too can
01.03.2008, 02:34 PM
so I'm back where I started months ago. I should get a neu but they are almost $300 and the MMM combo will(supposedly) be about $300 with the same motor. I hope castle gets its stuff together, i need an MMM and a sidewinder....................
squeeforever
squeeforever's Avatar
01.03.2008, 03:14 PM
Actually the MMM will come with a Neu designed motor, but nowhere near the quality.
Oh, and Lehners are 2 polers.
B15
01.03.2008, 03:30 PM
Noone knows that yet.
squeeforever
01.03.2008, 03:46 PM
For the price, its not even possible for it to have the same quality. Its gonna be made by Castle, so its kinda obvious. It was only designed by Steve Neu.
B15
01.03.2008, 03:54 PM
Right, I think we can assume the quality wont be the same, but how much worse its going to be is still up in the air. For less than half the cost, if its quality 90% of the same Ill be happy.
Serum
Serum's Avatar
01.03.2008, 04:30 PM
You would be surprised what bulk-buy can do.
BP-Revo
BMW M Power!
BP-Revo's Avatar
01.03.2008, 04:58 PM
But its not bulk buy, its just mass production of the design. If I recall correctly, I heard somewhere that the "Castle Neu's" were going to be machine wound, while actual Neu's are obviously hand wound. This will be the discerning factor for quality. I'm sure other than the winding, most other things will be very similar.
01.03.2008, 05:37 PM
Forgive my ignorance, but why would machine winding be much worse than hand winding? Seems like most machine produced items are made as well or better than if done by hand, like milling and automotive welding. I am sure there is some reason, but not one that I can see.
BP-Revo
BMW M Power!
BP-Revo's Avatar
01.03.2008, 06:02 PM
Apparently, machine winding is not as tight/precise as hand winding. This makes sense as because while a machine will just go around and around that pole to a set number of winds, hand winding can more precisely lay each wind down, and if there is a mistake (like a kink in the wire that throws off a certain wind), it can be redone.
sikeston34m
sikeston34m's Avatar
01.04.2008, 03:22 AM
This may be true for most regular conventional armature winds for brushed motors, and probably even outrunner motors.
But in the case of brushless inrunners, I believe these windings are "wound" or laid in a certain pattern, then compressed and baked inside a mold. When it cools, it retains it's shape so it will fit inside the motor can.
