Mamba Max on Neu 1512/2.5d at 4s Lipo
mabu
Mamba Max on Neu 1512/2.5d at 4s Lipo - 01.03.2008, 11:52 AM
Hi,
will this combination work ( long ) or would i toast the mamba max?
cart213
cart213's Avatar
01.03.2008, 01:56 PM
It will work but you are likely to get some cogging. I used the same motor with my MM and had bad cogging from a standstill. Once the truck gets moving, it is ok though.
mabu
01.03.2008, 02:02 PM
so rather use a mgm 12018-3 Car ?
i want to power a hyper 8 using mike's hyper motor mount
Serum
Serum's Avatar
01.03.2008, 02:03 PM
It depends; the MM controller are pretty sensitive. rumour has it that that Y winds run better on the MM controllers. While some people don't notice any cogging on their neu/mm setup others are experiencing a nasty cogging. According to the engineers at castle the Neu motors are slotted motors and need a software update on the MM, which isn't available yet, since they are focussing on the MMM and the Neu type of motors. I am sure that once the MMM/Neu clone is launched the MM will get a 'slotted' option in the software too
Serum
Serum's Avatar
yes, the MGM is a better choice for sure.
mabu
01.03.2008, 02:06 PM
Would also a 1512 3d work in the hyper 8?
i think it would be possible to change the gearing to work fine.
if possible, which motor is better/cooler? ;)
mabu
01.04.2008, 12:17 PM
can the hyper motor mount used within a hyper 8?
01.04.2008, 12:39 PM
The higher the number of turns, the cooler the motor will run in principle- input voltage will need to increase however to maintain the same speed (gearing up can only work to an extent before the motor & esc become overworked).
mabu
01.04.2008, 12:45 PM
Ok - so i will stay at 2.5d using a mgm 12018-3 c/b ...
the big question now is, if the hyper motor mount fits also at hyper 8 models
01.04.2008, 12:54 PM
I imagine so- if all the hyper vehicles share a common center diff design, then the RCM motor mount should just bolt right in place- I would suggest looking around the forum to see if anyone else has done a conversion on the hyper8 and used that mount.
mabu
01.04.2008, 12:58 PM
thanks - i only found hyper 7 conversions in the forum using the rcm motor mount ...
i gonna contact a hobao team driver .. may be he knows
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
01.13.2008, 02:32 PM
What about running a Neu/MM until the MMM ESC comes out? Would it be that bad?
:D
mabu
01.13.2008, 02:42 PM
At the moment i want to use a Lehner 1940/8 with the Mamba Max.
The Hobao team driver was not able to solve my issue - let's hope that the mount fits
