aqwut
Brushless Heavy Weight....
aqwut's Avatar
01.15.2008, 05:32 PM
the LMT 2280 on 12S is able to push it without a problem... I had a 26cc Sikk City modified to 7.5 HP... and for brushless... to match the power/speed of a Gas 7.5HP you probably only need 3000-4000 Watts....
Just for the heck of it... I'm gonna put a KB45 on 12S 25C 3700mAh into my Firehammer and see how well it performs... I'm only say this because my 12XL is able to push an 18Lb Monster truck without a problem.. and the baja is about 21 Lbs... my Firehammer is 21Lbs as well..
Do you guys have any idea what pitch the 1/5 scale uses?...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
tashpop
01.15.2008, 08:58 PM
you know i seen some rtr brushless 1/5 scales the other day. i think carson or carlson or something like that was building them. cheap too. ?$800 or somewhere close to that. they had a buggy and a onroad car. anyway, i'm posting this because they may have your pinion you need.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
cembom
01.15.2008, 09:16 PM
Why not take a smaller car and use the elecs? Like a 1:7 4wd. Alot cheaper and more fun lol. So aqwut are you actually saying you have that big outrunner in a firehammer?
lutach
lutach's Avatar
01.15.2008, 09:23 PM
I waited until this link was working: http://www.megamotorsusa.com/Brushle...-50.htm?id=642
What a work of art. I might just go for it.
nl12
nl12's Avatar
01.15.2008, 09:40 PM
How much does a baja weigh without the engine and gas tank
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
01.15.2008, 10:30 PM
Personally, I have recently calculated the approx. cost (not including little odds and sods) to built a Baja buggy with enough reliability, runtime, and power... the cost came to over $3000. This is using such components as a Neu 2230, a decently sized A123 pack that would have at least 7000watts capability, i can't remember which controller I priced in, but expensive none-the-less.
In time, I might attempt one of these... and when I have more 'surplus' budget.
It would be a sight for sure!
aqwut
aqwut's Avatar
01.16.2008, 10:17 PM
It's in the process of going into the firehammer... I need to build a special mount for both ends of the outrunner shaft to compensate for the vibration and bounce when jumping....
rhylsadar
rhylsadar's Avatar
01.17.2008, 04:33 AM
hi
i have thought of converting one of my large scale models too for some times.
personally i had thought of a 3040 lehner or the bolido with the big schulze and a small watercooling system. in contrast to the nitro models the cheap gasoline for the largescale makes it harder to convince onself that it such a great idea to go electric. furthermore one of the features i like most with the big models is their runtime of 40min with one tank. so i guess i would want the electric car also have runtimes around 30min. that takes quite some batteries.
however i have abandoned the idea so far. but who knows. to see my fg mt going as agressive as a bl savage or stampede would sure be awesome though.....
bye
rhylsadar
______________________
Exercitatio artem paravit
rhylsadar at youtube
