Originally Posted by bensf
Is it ok to have a chrger on a car battery while its on? I could see some problems with fluctuating voltage etc.
Aside from the safety aspects of charging inside the car while driving, these are the points to consider:
A typical car battery is between 40 and 60Ah. Pulling 10A for an hour will deplete it somewhat, but shouldn't keep you from starting your car unless the battery is older and/or it's cold out.
A car battery is really designed for short high current bursts (like for starting where over 500A can be pulled). If you want to pull a steady relatively low current, a marine battery is best.
While the car is running, the alternator puts out a loosely regulated 14.4v. Of course, there is some fluctuation, but it should be really close to that. This higher voltage will cause the charger to require less current than it would if the car was not running (battery at ~13.8v).
The only way you would blow a fuse is if the circuit was not designed for the current you are pulling, or the alternator voltage is higher or lower than it should be. Noise should be fairly low since the battery acts like a form of ripple filter. If you are really worried about it, a 20v 10,000uF capacitor on the charger input would suffice. Gotta remember that there are all kinds of electronic devices on board (radio, car computer, etc) that need a clean power source, so it can't be that bad, except maybe on older cars.
If you want to protect the car's battery, I'd pick up a yellow or blue top
Optima battery to power the charger. They are safer and lighter (no lead and acid), but are expensive. Just charge it at home in lead-acid mode at the end of the day.
