Good motor? -
01.31.2008, 01:10 AM
01.31.2008, 01:13 AM
IMO, no. 36mm diameter is normal for 540 motors, and that one is 28mm in diameter. That motor with a 36mm diameter should be pretty good, though.
01.31.2008, 01:15 AM
well I'm looking for a $ cheap motor that is in stock.
if this helps all i am doing is upgrading for a mm7700 that i have been using.
01.31.2008, 01:53 AM
upgrading from not for a mm 7700
01.31.2008, 09:19 PM
Something in the 2000-2300kv range, and 36mm diameter & 60-70mm length is what you want ideally. Feigao seem to only produce mtors when there is a big enough demand, so hence why they keep going out of stock quite often everywhere.
01.31.2008, 09:24 PM
01.31.2008, 09:33 PM
I think we have all pointed out that this is too hot - max to go with is 7XL - even this runs hot - 8XL would be better.
01.31.2008, 09:37 PM
In terms of size and specs, that motor lineup is a lot like the Feigao XL lineup. I wonder what the quality is like on them.
where would i get one in stock?
01.31.2008, 09:40 PM
i understand it might get hot, but i don't rod the piss out of my truck anyway, and i would be able to tell you guys about the quality.
01.31.2008, 09:57 PM
01.31.2008, 10:14 PM
are they in stock?
01.31.2008, 11:17 PM
yes by the looks of it
