mamba 4600 on 4s or 6900 on 3s? which is faster? -
02.04.2008, 11:40 AM
i decided i am going to go BL/lipo in my tc3 now. itll be a PURE speed machine. which of the 2 setups in the title will be faster?
02.04.2008, 11:44 AM
4600rpm/V x 14,8V = 68080rpm
6900rpm/V x 11,1V = 76590rpm
=> The 6900 on 3S will spin faster.
02.04.2008, 11:46 AM
Although the 4600/4s combo may tolerate higher gearing better since you're looking for high speeds only...
That's All Folks!
02.04.2008, 11:48 AM
Both are over the max rpm of the motor, I would go with the higher voltage set up, may run a bit cooler.
02.04.2008, 12:18 PM
yeah, thats what i was thinking. thanks guys. ill have it ordered within the month.
2 KiloWatt RACER
02.04.2008, 01:13 PM
Pick the lower kv motor and gear up. I only dragrace with 5000kV motors and below. The higher kv motors just draw too many amps, dropping the voltage too low, making reaching the topend harder.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
02.04.2008, 01:29 PM
Just a thought - why not a 5700 on 4s A123 as a compromise - I think this is what stampedeproject was running...
02.04.2008, 11:55 PM
I am running a TC4 I just finished. 4600 on 4S with 25/75...74mph!! Motor and ESC temps at 100 or so!!! It is a good setup for playing around. Easy 20 minutes on Apogee 3800's. I dropped in a 5700 to see what it will do Wednesday night.......
Funny thing, I did this setup once before with a Cyclone and junked it because the 4600 on 4S would melt the diffs after 2-3 runs!! Few months later, I help someone setup a bone stock HPI Sprint 2 w/ a 7700 on 3S with 33/81 gearing and WHAM, 84mph on the radar!!!!! SOOOO, I am back again to prove a point!!
02.07.2008, 08:22 AM
Just an update: 5700 on 4S, 32/69.........84mph!!! Slowly climbing
"Out of spec" enthusiast
02.07.2008, 04:19 PM
Do you have to use the mamba motors? The novak 3.5r went 79 mph one year at the worlds fastest rc-car challenge on just 2s. Last year the HV4.5 went over 100 mph on 4s and 118 on 5s. These were just off the shelf setups too.
2 KiloWatt RACER
02.07.2008, 04:51 PM
I use to run 4s A123 with the 5700. It was silly fast, but heated up to quick.
02.07.2008, 05:43 PM
You guys know that the 6900 should not be ran on 3s right? It is not made for that high of rpm, and will heat up very fast. Not a good idea imo.
Faster than a cheetah on cocaine
WARNING: May become violent.
02.07.2008, 09:30 PM
Like PB said. Not only will it be dangerous and void the warranty it will heat up very quickly. Castle motors tend to do that...
2 KiloWatt RACER
02.07.2008, 09:56 PM
You forgot that you are on the RCM forum. The peeps here are brushless experts.
02.07.2008, 10:07 PM
I guess... I still wouldnt use Castle motors if your going for all out insanity.
