Having 2nd Thoughts...(Help Me Choose)
Takedown
WARNING: May become violent.
Takedown's Avatar
Having 2nd Thoughts...(Help Me Choose) - 03.02.2008, 09:30 AM
I was originally planning to get the Mini MGT but Im having 2nd thoughts. My bro is gonna be buying a Savage X 4.6 to convert to electric. I now want something equal in size or bigger. I was looking at the LST2 and the Cen GST 7.7/Nemesis. What one would you rather have? The cen has its ups/downs and the losi has its ups/downs. Im looking to run 5s with the MMM ESC and a possible Neu/Lehner motor. Any idea's?
Thanks
Takedown
Takedown's Avatar
03.02.2008, 09:38 AM
Here's some pics...
LST2
GST 7.7
tashpop
03.02.2008, 10:28 AM
from what i understand, both will be bigger. lst 2 will out handle the savage, gst will run over the savage if you can get lucky and catch him.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
jzemaxx
03.02.2008, 02:24 PM
I am going to convert later this year a XTM Monster MT. Its bigger then all the above mentioned and the weight didn't look to bad. I think around 13lbs.
supralover72
supralover72's Avatar
03.02.2008, 02:27 PM
I don't think you realize just how big the genesis is. It's HUGE. Infact, 5s may not even be enough for it without running too hot. I would def. Do the losi if those are your only choices.
Takedown
Takedown's Avatar
03.03.2008, 09:28 PM
Their is no budget as of right now so thats why I have the GST 7.7 on the list.
gogglespaesano
gogglespaesano's Avatar
03.04.2008, 01:50 AM
If you go with losi, look at the aftershock, especially if you plan on converting it. amainhobbies has it for 309$ and they always have 25$ off coupons.
The aftershock is nearly the same as the lst2, and with the upgrade kit 100-120$, you can basically make it into a lst2, only with plastic shocks instead of aluminum. You can then spend the 300$ you save on other upgrades, or your electric conversion.
Worth taking a look.
03.04.2008, 02:27 AM
+1 on the aftershock, no need to buy the lst2. You could also buy the raminator or the mega baja, one of them even has a dsm radio setup.
Haldir
03.04.2008, 10:16 AM
What's the Amain code? I might need one soon .
gogglespaesano
03.05.2008, 12:17 AM
If Your Order Totals: You Save! Refer to Coupon#
$100.00 - $149.99 $5.00 DPPMAR85
$150.00 - $249.99 $12.50 DPPMAR812
$250 or more $25.00 DPPMAR825
good at amainhobbies until apr 30, 2008
