mtroniks esc
drkros3
mtroniks esc - 02.26.2008, 09:43 PM
just wondering has any one ever set a mtroniks esc. its the pro genesis esc.
i know metalman u have if u could help me that would be great.
i have read the directions just cant seem to get it into the programing mode.
lutach
lutach's Avatar
02.26.2008, 10:31 PM
It's easy, but you might fry it like you did the Sidewinder. If it's like the truck controller, it should be easier then a MGM. Later I'll get the intructions for my Mtroniks and walk you through it, but if some one else post it here, I'll just come here to see how the controller is running. It's a nice controller ad if you are thinking about smoking this one, send it to me and I'll take good care of it.
drkros3
02.26.2008, 10:37 PM
wow thanks for saying that. lots of support.
its cool i got the esc working. finally programed it.
lutach
lutach's Avatar
02.26.2008, 10:44 PM
Ok. No problem. Use it with care. Report back on how it's running.
drkros3
02.26.2008, 11:18 PM
oh its running great with no bec!
lutach
lutach's Avatar
02.26.2008, 11:25 PM
That's good.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.27.2008, 12:22 AM
Be careful with the Mtroniks + high voltage without a UBEC.... that's how mine smoked. The internal BEC can and will burn up on 4s, even when the controller seems to be running cool.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
drkros3
02.27.2008, 12:48 AM
the esc is not even getting hot. i was really suprised when i was done running and i touched it and it was not even hot.
lutach
lutach's Avatar
02.27.2008, 12:57 AM
Since we are on the mtroniks topic. How do I remove the resin to see the inside of the controller?
MetalMan
MetalMan's Avatar
02.27.2008, 01:05 AM
You can let it burn itself, that'll get rid of the resin (as I've experienced twice).
The Mtroniks are some really weird ESCs. I never was successful using one with a UBEC, and for a while one of them was fine running the internal BEC on 5s LiFePO4 (16.5v nominal) (it smoked, and Mtroniks promptly replaced it for free).
Have you gotten the programming figured out already? It's been a while since I've programmed mine (since it smoke 6+months ago), but I'm sure I can figure it out again.
drkros3
02.27.2008, 01:15 AM
yah it was a really weird programing. i just hope i did it right. i was trying to set the lvc on it and i think i did it right. but im still driving it for a few min. and then checking the voltage on the battery to see if its working lol. but have not gotten the battery down that far yet.
i well fine out tomorrow.
drkros3
03.06.2008, 01:12 AM
hahah ok since i posted this thread i have fried 3 of these esc. and i did everything right. every time i used a castle bec and had it programed to the right settings.
these esc's suck! lol
i put in a mamba max and it works great. i dont kow what i was thinking going with these esc's
lutach
lutach's Avatar
03.06.2008, 01:33 AM
wow. Something must be wrong. Get a datalogger like the Eagle Tree or DPR and find out what is going on.
drkros3
03.06.2008, 01:41 AM
datalogger???????
explain please
lutach
lutach's Avatar
03.06.2008, 01:51 AM
datalogger???????
explain please
If you are pulling too much AMPs you will burn your ESC. The Hobby shop you work for doesn't have Eagle Tree products? Here are more info on them: http://www.eagletreesystems.com/MicroPower/micro.htm and http://www.bnbproducts.com/.
