Tmaxx Brushless Convert
xcntrk
xcntrk's Avatar
Tmaxx Brushless Convert - 04.03.2008, 08:25 PM
Hey all, just finished converting my 4-year old Tmaxx over to electric with a full brushless setup and thought I'd share some pics. This basher started off as [what’s now called] a Tmaxx “Classic” with a tiny .15 nitro motor. I built it up pretty good back in 2004 with a big-block .21 and lots of UE parts. It’s been sitting in a box for the past 3 years and I just recently dusted it off, ditched all the stinky nitro crap, and started the electric conversion. Here's my spec's:
  • MM, w/2700mF Cap & Fan
  • Fieago 7XL w/RCM sink-clamp
  • CC-BEC
  • Receiver Cap (glitch-buster)
  • PolyQuest 4s 5000mah lipo
xcntrk
xcntrk's Avatar
Before (nitro):
After (BL Convert):
How's it look?
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
04.03.2008, 08:29 PM
Looks pretty sweet. Looks like it needs to be on a race track though.
xcntrk
xcntrk's Avatar
04.03.2008, 08:36 PM
^Thanks…
No racetrack for me I’m a terrible driver; that’s why it’s built up with the stronger parts. If it breaks (frequently) replace it with something stronger, at least that’s my approach. I beat the crap out of this rig and have for years. It’s still going…
luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
04.03.2008, 08:48 PM
GREAT TRUCK AND GREAT JOB MAN.
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
04.03.2008, 08:54 PM
Nice job! What kind of tires are those?
aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.03.2008, 11:56 PM
Awesome dude.. it's basically an E-Maxx now... how much that thing weigh?..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
jnev
jnev's Avatar
04.04.2008, 12:16 AM
Looks great man!! Nice job! Did the E-Maxx tranny go right in or were new holes needed to be drilled?
aqwut
aqwut's Avatar
04.04.2008, 12:29 AM
The holes should've been perfect for the tranny... the PolyQuest packs looks beautiful man...
04.04.2008, 12:50 AM
Nice maxx, make me want to finish my racebomb...
xcntrk
xcntrk's Avatar
04.04.2008, 08:05 AM
Thanks for the feedback all!
They’re Axial Terra-izers in 40 series.
It’s essentially an Emaxx tranny with motor plate installed on the UE Thunder (nitro) extended chassis. The Emaxx tranny mount is the same as the nitro tranny, but it is a taller box and hangs down lower then the original unit (beyond the frame rails). This prevents my center skid from clearing. I’ll probably shim out the skid to make it fit. Also the Emaxx tranny has a shorter output shaft and required a custom length front dogbone. Took me a while to find the right size; I'm presently running a 72mm but 70mm would be ideal.
great idea!
plettenbergs
plettenbergs's Avatar
great idea! - 04.04.2008, 07:42 PM
i have a chassis and emaxx trani laying around...what rear drive shaft did you use?...where did you get the front one?
04.05.2008, 08:42 AM
an e-maxx tranny on a t-maxx chassis needs about 1/4 inch spacers under the transmission to fit perfectly, like xcntrk was mentioning about his center skid not fitting, he said he was going to space out the center skid, but driveshafts fit better if you space the tranny, as the e-maxx chassis is thicker and makes the tranny sit higher than on a t-maxx chassis
xcntrk
xcntrk's Avatar
04.05.2008, 08:51 AM
^Thanks I’ll have to look into that. Personaly I’d prefer the tranny to sit lower as the dogbones closer to level and therefore don’t wear as quickly. Too late for me, if I shim the tranny up I’ll have to hunt for new dogbones (again).
Tell you what, I’ll save you trouble and trade-ya strait across for your dual-plet maxx
I used my original UE thunder chassis rear dogbone; then I had to source a front bone. With the tranny mounted flush on the chassis (non-shimmed) a 70mm front dogbone will be perfect. I’m running a 72mm and it’s just a tad tight. Mike can get either 70 or 72mm bones.
pedeboi364
12.31.2008, 03:27 PM
nice job. u think i could use the stock tranny and put my batts where the rx batt was??
Check out my FS thread in the General Discussion!! Help me go lipoly!!!
