1/10 onroad car choices...any ideas -
05.11.2008, 05:56 PM
Just pondering getting a on road sedan to fart around w/. It will be brushless...any ideas, I know NOTHING about these cars
05.11.2008, 06:05 PM
So you are wanting a electric one or a nitro kit converted to electric?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
05.11.2008, 06:16 PM
Electric kit
05.11.2008, 06:22 PM
You could probably pick up a Team Associated TC4 pretty cheap on ebay since your only farting around with it. That is the only 1/10 electric kit I have used/owned
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
05.11.2008, 06:34 PM
Had good luck w/ it as far as reliability...What was your set up?
05.12.2008, 12:48 AM
It was just a fart around car aswell but not using Brushless, just a 15t Peak motor powered by a Novak ESC. A good thing with the TC4 chassis is that it can also hold 7 cell batteries and being shaft drive doesn't require as much maintaince which means more farting around time
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
05.12.2008, 06:24 AM
maybe a vxl 4tec?
05.12.2008, 09:45 AM
I had a TC5 for a while and absolutely LOVED it. I ran a 12t Speedgems motor and a MM ESC on 6 cells. Then I sold it for $750. Really loved the car, though but the offer was too good to pass up.
05.12.2008, 09:56 AM
Just grab a TC3. Unless you are racing hardcore, you dont need a TC5. Tons of parts for TC3, they are cheap and durable. If you cant win a race with a TC3, you are doin something wrong.
05.12.2008, 01:20 PM
I had a TC4 with a Mamba Max 7700kv kit in it running a 2s lipo. I loved it, but had to sell it to finish another project  It had good run time and was stupid fast. Foam tires are needed on loose surfaces though. I can remember my gearing, but i know it would do close to 70mph. I used it for burnouts, donuts, drifting, flying, shear terror, speed runs, and running on the practice track.  It held up well though, i lost a lugnut and slung a tire.
05.12.2008, 05:06 PM
Definately go with a TC3/TC4. Running 100+ on a 5700 4S setup. Takes the power all day with no problems AND takes a beating!!! I have had quite a bit of blow overs at 90+ and no problems!!!!
05.12.2008, 05:16 PM
Love my TC3s. Can't go wrong with them. Tons of cheap parts available and awesome carbon fiber chassis options if you want to go that way as well.
05.12.2008, 06:13 PM
Originally Posted by brushlessboy16
maybe a vxl 4tec?
Is there a VXL 4TEC? If not, wonder if Traxxas is looking at bringing it out
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
05.13.2008, 10:40 AM
TC3/TC4 is the way to go, sturdy, cheap, shaft drive, no belts. My TC3 takes the mm/7700 combo no problem and the gtb/5.5 before that. Lots of high speed crashes, lots of destroyed tires and it still runs.
05.13.2008, 04:49 PM
lol, must be a real handful to control the TC4 on 7700
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
