DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.28.2008, 02:11 AM
Originally Posted by tc3_racer_001 View Post
havent heard many good things with those extreme lipos... the flying guys are dissapointed in them.
I thought that was the 1st series and the V2's are one of the best packs on the market?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
tc3_racer_001's Avatar
05.28.2008, 03:55 AM
yes, i may be wrong, but the bad ones were great for 50 or less runs then pretty much useless...
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
05.28.2008, 10:12 AM
Had my Hyper 8 geared with a 16T pinion a while back and it was waaayyy too much for a small track.
Now I get about 30ish minutes of runtime with dual MA 8Ah 2s packs, 1512 2d/f, geared for around 45mph (14t pinion) and it is quite fast and still has tons of torque. Temps are very good too. Actually, it's almost too torquey for a small track geared at 14T.
VintageMA
VintageMA's Avatar
05.28.2008, 03:52 PM
Originally Posted by MetalMan View Post
4s is often plenty to surpass the nitros in both acceleration and top speed. I'm running 4s with a Neu 1512 2.5D/F in my Hyper 8, geared for ~45mph, and everything (MM + batts + motor) run at very acceptable temps.
I thought that 4S was kinda "the standard" because that was what ROAR (or whoever makes the rules) decided was the fairest max LiPo cell count to keep things even with nitros.
“Everyone has a right to be stupid; some people just abuse the privilege.”
MetalMan
MetalMan's Avatar
05.28.2008, 05:54 PM
I had no idea that ROAR or any racing organization made a ruling on 1/8 electric.
VintageMA
VintageMA's Avatar
05.28.2008, 06:22 PM
You may be right. Thought I had remembered reading something else somewhere though.
Found this:
http://www.roarracing.com/downloads/...ipo_Reader.pdf
but seems to be about 1/10 scale.
skellyo
skellyo's Avatar
05.28.2008, 06:26 PM
I believe it may have been the RC Pro series that went with a 4S standard for electric 1/8th. I don't know that for sure, but I seem to remember reading that on rctech.net.
DRIFT_BUGGY
05.28.2008, 06:45 PM
I'll just be doing club racing (probably against nitros) so nothing to serious. Just got to find more info on the TP V2 Batteries and if it is worth spending $45 more on a 5S over a 4S
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
skellyo
skellyo's Avatar
05.28.2008, 06:52 PM
My guess is that they went from 20C to 25C cells or some small change like that. They use Enerland cells, so I wouldn't hesitate to use them myself.
VintageMA
VintageMA's Avatar
05.28.2008, 07:14 PM
I just bought a bunch of TP V2 packs and my initial impressions are very good. My TP V2 5S 3850 keeps up just as good as my 5S Neu 3900 pack. No idea on longevity yet as they are all less than a month old.
Also picked up some 6S TP V2 2600 packs for when my XB8 when my 1512 3.5D Neu comes in.
DRIFT_BUGGY
05.28.2008, 09:04 PM
Yeah the TP 5S 5000 is pretty much the same price as the Neu 5S 5000 but I have $400 credit at Amain that I got to use up but still don't want to use the $400 on crap batteries that don't last. No-one has the Hyperion Adaptor to TP balance tap, how long could I run the batteries till they need to be balanced?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
VintageMA
VintageMA's Avatar
05.28.2008, 10:33 PM
Try here for balancers:
http://www.rclipos.com/Balancers.htm
azjc
05.28.2008, 10:49 PM
MaxAmps does
http://www.maxamps.com/proddetail.ph...ULTI-TP&cat=34
DRIFT_BUGGY
05.28.2008, 11:52 PM
Sweet, thanks, free world wide shipping to
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
Motoman
Motoman's Avatar
05.29.2008, 06:11 PM
The TP Extremes are one of the best batteries I've seen. In fact the past 2 weekends in a row I went out to the track and have been driving my X-1 CR on an approximately 1.5 year old Extreme V1 3s 25C 2070 pack and it runs fine. The only problem with that setup is that the battery is too small both in cells and capacity. But, it's just to test the buggy and it gets me about 10 min. After I run that battery to the 9v cutoff it's a little hot but it stays balanced throughout the entire charge period.
The other battery that I ordered will be a lot better suited for the job (TP extreme 6s 3850). I figure I should get around 45-60 minutes with that pack.
Heli guys swear by Thunder Power's Extreme lineup including myself.
tc3_racer_001:
Who told you the Extremes were bad batteries?
