david lamontagn
06.25.2008, 04:09 PM
Recommended by Neu (from another forum I believe), as I have heard this as well. Also the instruction sheet that comes with the Neu motors (you do read the instructions right?) says low timing.
exact, on the Neu website
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.25.2008, 06:00 PM
The temps are while running at my local track. I am using the standard Losi XRT (or something like that) tyres.
Here is a shot of the MMM specs
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
06.25.2008, 06:01 PM
I didn't get no instructions with my motor.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
KaztheMinotaur
KaztheMinotaur's Avatar
06.25.2008, 06:23 PM
Me neither.
david lamontagn
06.25.2008, 06:35 PM
If the value "10" on the motor timming case is the value giving in degree, i find it little high for a "d" motor. Try to put it at 0, or if you have the option "automatic timming" as on the MGM controller, put it on automatic.
DRIFT_BUGGY
06.25.2008, 06:43 PM
Thanks, ill give that a try, the 10 is what the ESC was set to and it said normal so I just left it at that
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
Mozzy
Mozzy's Avatar
06.25.2008, 06:49 PM
I too was beginning to wonder where my destructions were.
Luckily I'm not the only one.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
DRIFT_BUGGY
06.25.2008, 11:04 PM
Might set it at 3 for now since it was set at 10 before and wasn't running crazy hot, see how it goes from there and still nothing change try 0
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
tc3_racer_001's Avatar
06.26.2008, 02:32 AM
in my experience with other motors, the timing doesnt seem to do much at all except raise temperatures. would you be able to tell the difference between 3 and 0?
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
06.26.2008, 02:56 AM
That's interesting to know about the timing. Let us know what the difference is temperature wise when you drive it on the track again.
azjc
06.26.2008, 02:58 AM
I would agree with that...
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
06.29.2008, 08:08 PM
So what was the outcome drift. Did the temps come down? I am very tempted to copy your setup.
DRIFT_BUGGY
06.29.2008, 09:58 PM
Well just got back from the track. With it a 3 degree the motor still got up to 170F and the ESC up to 128F, battery 95F - 110F. Im now going to set the timing to 0 and put the larger 15T pinion in instead of the 14T which will raise the top speed to 47mph. My local track is fairly large. I have some thicker centre diff fluid (10000, standard in roller 8ight is 5000) coming to. If that doesn't change the temp I might look at putting a fan behind the rc box which will flow air straight onto the motor and try to work out how to go more air flow to the motor. This is a great buggy to drive and once I work out how to get the motor to stay cool, im laughing
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
entjoles
06.29.2008, 10:39 PM
i ran my xt8 at the track yesterday , and i ran 4 packs, i had been running 0 timing but i changed it to 12, my temps went from 165 down to 155, but i was on a track and not wot bashing, but i think it helped.......
1515 1y , 4s , 17/48
DRIFT_BUGGY
06.30.2008, 12:05 AM
Well changed to 15T pinion and timing to 0 and went down to the track and after 8 minutes again same temps as above. I thought it was running better as I perfered the 15T over the 14T but after brining it in to check the temp. I don't think I mentioned in the 1st post that I have a front cover in front of the motor to stop debris getting in the holes.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
