Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
HB Lightning 2 Pro Evo
Sammus
Sammus's Avatar
HB Lightning 2 Pro Evo - 07.03.2008, 10:04 AM
Is there a brushless mount available for the HB Lightning 2 Pro Evo? Or is it/would it be the same as the stadium mount?
Cheers
07.03.2008, 10:23 AM
http://www.rc-monster.com/proddetail...=LSPmotormount
I think it is this one
Sammus
Sammus's Avatar
07.03.2008, 10:27 AM
Yeah I meant just stadium instead of stadium 10. So the truggy mount is the same as the buggy mount? It seems like a fairly safe assumption but I want be sure before forking over the $$ :P
07.03.2008, 10:42 AM
Have you check HB part nos?
Maciolus
07.03.2008, 11:11 AM
Check out my pics:
http://picasaweb.google.pl/Maciej.St...61719668981634
Truggy motor mount fits perfectly. You just need to use truggy front Differential Fixing Plate
http://www3.towerhobbies.com/cgi-bin...I=HBSC8150&P=K
Good luck with your project!
> HB L2PE + MMM + Medusa 60-1600 @ 6S A123
> HB LSP + MMM + Medusa 70-1600 @ 6S2P A123
> AE B44 + MM + Medusa 50-3300 @ 4S A123
> AE J82 + SW 5700 @ 2S LiPo
> AE TC5R + MM 6900 @ 2S LiPo
Sammus
Sammus's Avatar
07.05.2008, 06:02 AM
awesome cheers
Sammus
Sammus's Avatar
07.05.2008, 09:53 AM
Before I go ahead with my next project (this) is there anything at all you can tell me about using those diff supports? does it change anything at all? the height of the diff or anything - does the top plate still work and the stock brakes still fit etc (in case i want to run mech brakes)?
Maciolus
07.05.2008, 10:09 AM
It just elevates diff approx 2 mm. Top plate works perfectly. I am using motor brakes, but I think mechanical brakes will work. You just need to use Mike's brake spacer:
http://www.rc-monster.com/proddetail...rontmotorcover
