CC how about a custom MMM case?
auto2
CC how about a custom MMM case? - 07.15.2008, 10:02 AM
one that can be bolted to the chassis with shock mounts or something.
tape is not the hot set up.
i would pay extra :-) maybe fancy color choises LOL
or a sideways mount so dirt wouldnt fall into the fan as much.
water cooling would be nice too.
i drilled and tapped my chassis. then taped the mmm to a piece of carbon fibre. bolted the carbon to the chassis and then ran a wire tie around it all so when the tape gives up the ghost i can finish the race.
Plus i can unscrew
it for cleaning.
so a case with ears and rubber gromets woud be hot.
07.15.2008, 12:21 PM
good ideas..maybe someone is listening....
07.15.2008, 12:36 PM
How about a dye-able case (white?) with mounting ears and rubber grommets...
Pdelcast
Pdelcast's Avatar
07.15.2008, 01:17 PM
What... like prom shoes?
Patrick del Castillo
President, Principle Engineer
auto2
07.15.2008, 01:19 PM
oh yea! like the pink cell phone cover my daughter wants.
i just dont trust tape for any length of time.
oh! an upside down mount that makes the chassis the heat sink....
can u see i'm bored at work today:-)
Pdelcast
Pdelcast's Avatar
07.15.2008, 01:21 PM
Pink ESC... hmmm the possibilities...
Anyway, mounting ears are a good idea. I only have about 8K cases made at this point -- we'll look at modding the mold.
No guarantees -- but we'll look at it.
Edumakated
07.15.2008, 01:30 PM
This is basically what I asked for on the other thread regarding a special edition. I just want a more secure way to mount the ESC. It would be nice to be able to screw the case directly to the chassis or ESC mount instead of relying on tap and zip ties.
07.15.2008, 01:39 PM
lol, I guess. Something like the type of milky white stuff RPM uses in their dye-able plastic/nylon.
auto2
07.15.2008, 01:42 PM
dont waste your 8K cases already made. just make options like xray does:-)
liquid cooling would be more durable? no? no mechanical moving parts. fluid moves by convection from a radiator to the heat sink? could cool motor also. cost maybe 100 bucks more? when do i send you money:-) im realy bored today...... ( AND THANKS FOR REPLYS!)
07.15.2008, 01:46 PM
Liquid cooling less moving parts? Convection would not move enough heat... You would need a reservoir, radiator and pump... More stuff to break....
You could use heat pipes to a larger heat sink but more to break IMO.
Just need a different case design with different mounting options - Missionary etc
azjc
07.15.2008, 01:51 PM
IMO the only reason you would want different colors for your ESC is if it was a shelf queen.......a radiator for an rc? sounds like the supercharger that they came out for nitros.....sounds like scam potential.....lol
07.15.2008, 02:06 PM
Ok, while we're at it, how about a heatsink that's just a slab of aluminum with screw taps in it? Then, we can add any heatsink, heatpipe, liquid nitrogen setup we want.
07.15.2008, 02:20 PM
I would like a case design that will allow for reverse cowgirl mounting....
VintageMA
VintageMA's Avatar
07.15.2008, 02:25 PM
Hey - come on - anything is possible.
Only things I am waiting on before I get back into nitro is electronic ignition, variable valve timing, 4-stroke engine, with self-tuning on board processor. I'd add direct injection fuel system but I dont want to push it too far.
“Everyone has a right to be stupid; some people just abuse the privilege.”
bl-is-future
bl-is-future's Avatar
reverse cowgirl mounting. Now that is an ESC i want. I can see it now.
"THE ALL NEW MMM CASE! NOW INCLUDES YOUR VERY OWN COWGIRL. PERFECT FOR REVERSE COWGIRL MOUNTING!"
