Byte
08.06.2008, 11:39 AM
That are some nice ESCs! :D But they're very expensive.. :(
lutach
lutach's Avatar
08.06.2008, 12:11 PM
and how do you plan to keep tires under this car? take out a loan?
The foam tires that will (Well hopefully will) come can handle speeds of over 100mph so it should be good. The wings will also help keep it planted on the ground. Plus I've learned a long time ago how to manage throttle control with all this powerful brushless goodies we have available.
traxxasrevony
08.06.2008, 12:26 PM
if i was going to do a project with one of those it would be with a revo tranny and diffs on a custom pan car chassis heres the calc on it
Differential Ratio: 2.8461538461538462
Transmission Ratio: 2.111111111111111
Other Ratio: 1
Spur Tooth Count: 36
Pinion Tooth Count: 25
Total Voltage: 88.8
Motor KV: 660
Tire Diameter (inches): 5.51
Tire Ballooning (inches): .6
Motor Current Draw: 75
Motor coil Ω: 0
Spur/Pinion Ratio: 1.44 : 1
Total Ratio: 8.65231 : 1
Tire Circumference (inches): 21.08 inches (535.43 mm)
Total Motor Speed: 58608 RPM
Vehicle Speed: 135.22 mph (217.21 km/h)
Estimated Adjusted Speed: 108 mph (174 km/h) - 20% loss
Effective KV Value: 660
KT constant: 2.05 oz-in/A
Motor Torque: 0.8 ft-lbs
Final Torque: 6.93 ft-lbs
Final Power: 6660 watts (8.9 HP)
this is all hypathetical because i could never afford a 24s lipo
08.06.2008, 12:43 PM
That fool lutach was saying a 1515/3Y or a 1521/2Y (If it fits) would be a nice choice for a up to the red line F1 stuff. I think lutach is just a bit to think straight most of the time .
...Why are you referring to yourself in the third person? I think there is something else in that alcohol...
lutach
lutach's Avatar
08.06.2008, 12:45 PM
That was my crazy self talking , he does that sometimes.
Takedown
WARNING: May become violent.
Takedown's Avatar
08.06.2008, 01:06 PM
Lutach, you never seize to amaze me.
RIP- Tammy (9/14/08)
lutach
lutach's Avatar
08.06.2008, 01:39 PM
I've learned a few things from the best of this forum. They know who they are.
TexasSP
Something, anything, nothing
TexasSP's Avatar
08.06.2008, 01:48 PM
Lutach, you and linc are not allowed to play anymore.
That boy is a bad influence on you and nothing good can come of it!
You need to go to your room young man and think about what you did.
If I catch you with him again, you know the consequences!
www.cubicle101.com
lutach
lutach's Avatar
08.06.2008, 01:49 PM
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
08.06.2008, 09:18 PM
Originally Posted by hemiblas View Post
Wow, we should get together and design an electric car and use this as the speed controller. Get 4 of those 45mm kb motors, one for each wheel. We could have 4 wheel drive and 120 hp. Buy a couple of lipo's and we are in business. Can you image going to the mechanic and saying, yeah just put a new speed controller. Thats all we would need. I bet Joe has got his barbie keep going 80mph with some unlucky dude at the wheel begging to stop.
4 of them in a buggy or go cart would be sweet. 80kw in something small and light would haul ass. Runtime would be an issue though.
