Range of the neutral zone...what does this mean on the MGM controllers -
08.08.2008, 08:48 PM
What exactly does this mean?
Soldermaster Extraordinaire
08.08.2008, 09:02 PM
It's like this:
Reverse/Brake-------------------(((Neutral Zone)))-------------------Forward
When you adjust the setting it adds or removes the (( )) from either side of the neutral zone on the Tx channel. The Tx will not broadcast a signal when it is inside that zone. Basically it relates to how "touchy" the throttle is. If you make the zone too large, say for example the stock 12%, the throttle will turn on at 12% or the brakes will engage at 12% to start. There will be no resolution lower than that because those values are in the Neutral Zone. I find 6% works well.
I hope I explained this correctly. It was harder than I thought!
08.08.2008, 09:19 PM
perfect !!!
That's All Folks!
08.08.2008, 09:21 PM
It is the "deadband" @ neutral
08.08.2008, 09:31 PM
It seems sometimes we need " expert " technicians to help us at some point w/programming problems.
08.08.2008, 09:42 PM
Thank you, I think...??
I like to call myself "technologically intuitive". I'm also the computer tech for my neighborhood.  OK, I hate bragging so I'm done now.
08.08.2008, 09:45 PM
I am referring to you....  Thanks again!
That's All Folks!
08.08.2008, 10:07 PM
It's like this:
It seemed the older firmware would start out at higher % of throttle with wider neutral zone, but it seems like the new firmware starts at 0% throttle no matter what the neutral zone is. Also, setting the neutral too narrow (6% on mine) would sometimes not allow reverse to engage, or forward after using reverse.
08.09.2008, 02:53 AM
^^^ Interesting, I'll take note in case I buy a newer MGM.
08.09.2008, 09:24 AM
Funny you should mention that....I had the same issues yesterday too. I would engage rev. and then nothing...I will reset mine to 12% and see what happens.
That's All Folks!
08.09.2008, 08:38 PM
Yeah, 12% seems to work fine for me. Hope it works for you too.
