08.20.2008, 07:00 AM
i got the same program courtesy of school :)
i find it really difficult to make something im visualising. easy when im working off something solid so i can understand.
my deam is to redraw my entire car and make an animation of it being built, screws and all, twisting etc. i recon that would be freaky and sick at the same time :)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
08.20.2008, 10:19 AM
starting to get there...
08.20.2008, 10:46 AM
Hi,
Originally Posted by Arct1k
Motor mount please for a Hyper ST and X1CR but with the Motor down the centre line over the rear drive shaft with custom top plate...
I posted jpgs of Autocad LT dwgs of the very thing u refer to for the X1CR about 1 year + ago (could b nearly 2 years) but I cannot find anyone to make them.
Basically, it involves moving the center diff forward, tuck the batteries in saddle pack configuration closer to the center & motor at the center above the batteries. A top deck is put in to compensate for the torque rods that will not be there. At the time, I was dreaming of running 8S 4000mah using a BK3095. Unfortunately, still dreaming...
Regards,
Joe Ling
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
08.20.2008, 06:28 PM
08.20.2008, 06:30 PM
mike you better be watching in case you need a designer, "will work for lipos" :D
let me know what you think guys
08.20.2008, 07:05 PM
Keep in mind cutter radii. If you look at your part, the "eye drops" I'll call them (the two lightening holes on either side of the larger hole at the bottom of the part) will be very tough to machine. Otherwise it looks buildable
08.20.2008, 07:18 PM
we have a mini cnc router that used a 2mm bit- all the radii are 1.5 or more, should be fine
08.20.2008, 10:16 PM
Originally Posted by BL_RV0
Another A1 idea from Arct1k. If you could make the top plate integrated that would be awesome.
what guys no commentary?
08.20.2008, 10:20 PM
You forgot holes and a top plate... But...
i dont have a hyper st so i wouldnt know hole spacing
08.20.2008, 10:31 PM
Wing it  You dont need exact dimensions just for a rough design- think of it as sketching some ideas on piece of paper, only its on a computer instead. Exact dimesions can be corrected later on when you know them better. Looks kinda similar to the center diff unit mike made for the flm chassis:
http://www.rc-monster.com/forum/showthread.php?t=10233
Same concept really.
08.20.2008, 10:57 PM
very nice
WARNING: May become violent.
08.21.2008, 05:46 PM
RIP- Tammy (9/14/08)
08.21.2008, 06:20 PM
dont look half bad ryan :D
08.21.2008, 07:01 PM
Thanks ben. Its become an addiction now to me.
