Wich Neu for a Stampede??? -
08.26.2008, 09:51 PM
I want to slowly upgrade the Stampede of my son (it me who'll run it  ).
For now, i've change the idler gear for the steel one, and the diff for the VXL one.
Now i look for a good motor ( i've order this one for now http://www.unitedhobbies.com/unitedh...tor_13T_3000Kv but i look for a Neu motor soon.
What do you suggest to me, a 1512 or a 1509???????
I'll run it on 3s li-po.
Thank you
08.26.2008, 09:55 PM
a 1509 would be fine, 1512 might be overkill
Soldermaster Extraordinaire
08.26.2008, 09:59 PM
Do you have an aftermarket transmission case? The 15xx Neu's are too large in diameter to fit into the stock plastic transmission motor mounts. Unless you want to hack up the back of it.
08.26.2008, 10:01 PM
they shouldnt be, you can fit a standard feigao with a RCM heatsink in the stock trans
If i take the smooth can, should be fine, no?????
But i plan to order the FLM aluminium tranny case soon.
08.26.2008, 10:03 PM
should be fine either way
I would go with a medusa 50mm 3300kv in an 1/8th shaft if you want to keep stock gearing...
08.26.2008, 10:05 PM
Good and it's less expensive way too
Thank you!
08.26.2008, 10:08 PM
but 32p and mod1 can handle more abuse ;)
08.26.2008, 10:12 PM
Alright I take it back. Half of it. The SMOOTH can Neu 15xx will fit. I just tore the motor out of my GTP to convince myself.
So to answer your question, I think a 1509 will be plenty for a Stampede. A 1512 would be what some call "stupid city".
08.26.2008, 10:16 PM
but stupid city is great to visit....
5s lipo, and a 19t spec motor in a 1/10th scale is stupid city:D
08.26.2008, 10:21 PM
I think that the medusa 50mm, 3300Kv will do the job for the price, but i think that i'll need better rear drive shaft and a more solid tranny case.
No sure if the internal planetary gear in the diffs will hold on 3s li-po
08.26.2008, 10:25 PM
The diffs are tougher than you think. I ran 4s with a 9XL in my Rustler for quite a while. The gears will wear out eventually if you're constantly putting more than 1hp into them, so just have a couple spare sets around.
08.26.2008, 10:26 PM
me too
08.26.2008, 10:34 PM
in comparasion I have a VXL Rustler with a Feigao 9L(2700kv) on 4s with MOD1 gearing and I like the combo...IMO I wouldnt waste $225 on a 1509 the Stampede is pretty light, a while back I was thinking about going with a 1509 in the Rustler but the Feigao is working out fine
